Lithium compatible battrery isolator /charge controller 24v/48v
coachgeo
3,531
North of Cincy OH
Nothing. It's used as a buzzword. Apparently, it worked. :ROFLMAO:
Just like 'Digital TV antenna'......
wondered about that... get feeling that one leg gets wired to Lead Acid start/run batts and other leg to a lithium charger*..and that then that goes to the LiPO4 battery
Charger might need to be proprietary .. or a proprietary lithium battery with proprietary BMS that limits alt and/or cuts off alt. pre float or something like that
TechnoWeenie
1,793
Nova Laboratories, WA
It's a voltage controlled switch.
Once voltage gets above a set point it engages the relay.
It's so the engine starts and charges the primary battery then the relay engages to send juice to the auxiliary/house batteries.
Reworked LMTV
1,545
1,205
TN
Alternator lithium charge controller?/isolator 24v/48v just came across this... Might be great deal guys-n-gals.... IMHO grab one now at this sale price https://www.invertersupply.com/inde...MIyoalrsa1hgMVakhHAR3zXA-YEAQYAyABEgIgUvD_BwE
Granted I dont really understand how this thang works.... such as does it require special BMS on battery orr?? .
I use 3 Midnight Solar MPPT's. Victron has largest market share on charge controllers in RV's, but not sure that they are the best.
coachgeo
3,531
North of Cincy OH
looking closer... apparently there is more to this that just buzzword. It has a place on it to plug Lithium battery BMS up to it. My guess is when Lithium bank is full the BMS triggers the relay to NOT have the relay click over to send any voltage down that lithium charge terminal.
