M1165 - REMOVING REAR WALL - METAL CURTAIN
4x4nutz
133
Mico, Texas
Removed all bolts, inset screws, and cut all the seals we could see to remove the rear wall, but rear wall not budging. Do we need to take off the entire top to get the rear wall off? Installing slant back. Thank you.
  • Like
Reactions: OBX
tgejesse
289
Maryland
Lots of GLUE is my guess. I removed that rear window close out in my truck and I had to peel and pry the thing apart after removing all the bolts.
Good luck that stuff is HEAVY
4x4nutz
133
Mico, Texas
I figured as much. Definitely some type of adhesive.
Awol
595
MA
Probably glue/adhesive as said above. Should come off with a little prying.
I wish you were closer to me, I'd love to have that curtain!
  • Like
Reactions: 98G
GMVguy
114
Texas
Did you ever get the rear wall out? I am in the same situation. It won't budge!
4x4nutz
133
Mico, Texas
Just reversed what I did to take the rear curtain off, and used some heavy duty all weather sealant ( 3M 5200 Marine Sealant ) on all the metal to metal surfaces.
