M37 Horsepower Question
ab705
62
13
Maine
Over the years, I've heard the HP rating of the T-245 engine in the M37 bantered around quite a bit. Some say it's rated at 78 HP, while others say it's 94 HP. I'm OK with either one, but I'd like to affirm which is actually correct.
I have a copy of the Army/Air Force TM 9-1840A technical manual, "ORDNANCE MAINTENANCE, ENGINE, (DODGE MODEL T-245), CLUTCH, (BORG AND BECK MODEL 11828," published in June, 1952.
The information is listed as correct to 20 February, 1952. Following is an excerpt from page ii of the manual:
This manual is described as applicable to the M37, M42, M43, and V41. Following is an excerpt from page 1 of the manual:
On page 8 of the manual, as shown below, it indicates that the brake horsepower rating (gross) is 94 HP:
So, is 94 HP correct?
If you think it's 78 HP, I'd like to know the official government or manufacturer documentation for that information as it applies to the T-245 as used in the M37, not just something someone wrote on their website or in an article, unless they name, or have a link to, the official source.
As mentioned, it doesn't matter all that much to me whether it's 78 or 94 HP; I just want to get it right.
Thanks. :)
G744
3,653
Hidden Valley, Az
That fan eats up at least 5 HP, and your 25A 28V generator = 700 Watts , figuring 740 W/HP.
So at least 6hp are lost, not counting the water pump.
We are probably lucky to get 50HP at the wheels, what with the friction and hysteresis of the drive train. Just that 300 deg F transfer case has to get that energy from somewhere...
ab705
62
13
Maine
Yes, I totally agree that by the time power reaches the wheels, there are a number of significant losses.
I'm just researching the actual engine HP specification (gross, less accessories), so that I get it right in anything I write up about my project.
My M37 has a hefty 100-amp alternator (I believe it had been a radio truck), and when that's working at full output, I imagine that it would drain around 4+ HP. It has a four-belt pulley, partly for redundancy I would think, but also because combined with the fan, etc., it would put a pretty good load on the fan belts.
Edit: I haven't heard anything to the contrary yet, so for now I'll continue to assume that the T-245 engine in my M37 is rated at 94 brake horsepower, per the TM.
