Thanks all for your $ .02. I like to hear everyones thoughts and experiences. I believe I have enough information for what I was needing. With having 30yrs of experience mounting and dismounting tires of all shapes and sizes from earth scrapers, off-road quarry trucks to Pay loaders, ag tractors, wheel barrows and lawn mowers, and commercial heavy trucks, including 60yr old split wheels on shit spreaders. This is the first with using this style 2 piece wheel. Knowing with all the other tires and wheels Ive worked with do in fact only come off the rim when deflated, when air PSI is too low to hold the beads out to rim lip. With having 25ys driving experience in Commercial trucks, with 22.5 tires having a taper rim where air psi inside tire is ONLY thing holding the sidewalls outward force to hold the beads on the tapered rim lip. Driving 70-80mph down freeways it is IMPOSSIBLE for a tire to come off a bead even with having even less 50% of required air PSI to have the load rating they are designed for and they have no insert or bead lock insert. While looking at these 2 piece wheels having what looks like a 2” rim lip shoulder all the way around. There is no way on this earth the tire fly off the rim when driving. I would like to see someone even try to dismount one if these tires on a two piece rim without taking the rim apart. There is no bead groove to allow the opposite side bead to fall into to allow one to get tire bead over the rim lip. Ive laughed so hard at guys trying to remove commercial 22.5s off the wrong side of wheel…. Monkey hump a football sight!
Anyhow, no argument intention here with this reply, only speaking my opinion on it.
thanks people! God Bless and God help this country!!
