Help identify axle half shaft and necessary boots
mgFray
992
Southern Minnesota
One of my rear half shafts the boot tore on the hub side and the rotor side is cracked.
I replaced it with a GS-P branded hand shaft, but I’d like to rebuild it so I always have a spare ready to go.
This is a 1988 M998, but I suspect it has been upgraded in the past to 10k axles. Can someone identify if this is a 7.5k or 10.3k axle and help me figure out what boots are needed?
Rotor side is round all the way around.
Hub side also looks the same all the way around.
mgFray
992
Southern Minnesota
I'm trying to figure out if it's worth rebuilding (re-greasing and putting on new boots) or not. Since it's a 7k, I think the only real value would be as an "original part" and MAYBE as a spare half-shaft in case I break the 10k one I just installed.
Assuming, I can successfully re-grease and boot it, it'll cost about what a new (aftermarket) half-shaft will. So it's not really a money saving thing.
Any opinions? (My HMMWV is very much in the 'keep as original as possible, and within reason, use original parts'... The GS-P half-shafts I got from summit as backups, certainly are not original parts, but they're so much less expensive them AMG's version that falls within my 'within reason' guideline)
Coug
4,764
Olympia/WA
if going aftermarket buy from a large store like summit, rock auto, or physical parts store that sells them and has lifetime warranty. Buying from ebay/amazon or other unknown or questionable sources is usually throwing money down the drain.
mgFray
992
Southern Minnesota
Ya, I have a full set of GS-P axleshafts I got from Summit about a year or so ago. I bought them as spares "just in case". I have no idea what 'lifetime' warranty would even mean (or if it has such a warranty).
Mogman
10,496
Papalote, TX
You have to beat the 7K shafts apart, they are not put together with removable rings like the 10K or aftermarket half shafts have.
