Serpentine belt removal process.
Just have a general question on how to remove the serpentine belt on my M109r7 A2 hummve It has a 99 inch serpentine belt. And the fan seems to be in the way to release the idler tensioner. Do you guys have any tips or tricks that could help. Trying to replace one of the pulleys that has a bearing gone out in it. Thank you for all the helpful advice and advance.
Mogman
10,505
Papalote, TX
Welcome to the SS forums!!!
There are a couple different ways to sneak in there and get the belt on off, I am sure you will get some helpful responses soon!!!
HoveringHMMWV
1,368
AL
I use this Harbor Freight thin cheater bar…..
TNDRIVER
571
Cleveland,TN
Remove the passenger splash guard, insert 3/8 power handle.
Coug
4,769
Olympia/WA
I've managed to replace my serpentine belt several times by just leaning over the top of the truck and using body weight to push down on the belt where it goes under the top idler pulley on the driver's side, and just slip it off. It doesn't work on every truck, but I've done it on a couple and it worked for me.
