- 835
- 1,519
- 93
- Mesa Colorado
INTRO:
This is a new issue so I'd figure I'd start anew. As most know I've torn apart the truck to replace the oil pump, lots of lines, U-joints, reflash the ECM, reroute exhaust. All is back together (except fluids) but I'm trying to re-torque the TC bolts just as a PM. Since I can only access 3 bolts at a time out of 20, I thought I'd would crank the engine slightly to spin the flywheel.
Problem is, the engine won't crank (of course). This is the first I've tried it since reinstalling the ECM. Batteries are good and the AIH is coming on and off after turning main switch on. I'm using the remote panel but same problem exists when using the dash controls. Starter switch dues not activate the aux relay or starter. Panel shows all the usual lights when power is on but engine is off,.... "check trans", "charging system", "engine oil pressure", "AIH", "low air", "park brake".
I'm going to go see what relays are on, specifically the neutral relay. I assume the ECM is working since the AIH is going on and off normally.
Question: I have no coolant, motor oil or trans fluid in the machine. Will no trans fluid prevent the neutral signal from activating?
