TR-6060 transmission on a M1010? Anybody done it?
ballencd
101
Columbus, NC
Looking for a viable transmission for my M1010. Like the grunt of the 4.56 gears but need to do highway speeds also as I want to travel with Oliver. Has anyone put a TR-6060 in a CUCV yet? How does it do? Top speed? MPG?IMG_7377.jpeg
Jeepadict
783
Round Mountain, NV
4L80E swap is good as it gets for fundamental simplicity and form & fitment. The civvy Squarebody guys have been swapping them in for decades, and in most cases it only takes a few hours.
ballencd
101
Columbus, NC
That OD would give me a 54 mph speed at 1800 rpm which is too slow for the highway. That's why I'm asking about 6 speeds. What about the 6L80E transmission?
chevymike
485
San Diego, CA
I have been researching 6L80E swaps as well and I think the biggest problem I run into is, finding a transfer case that is a passenger side drop, that will mate up to the trans. Info has been hit and miss on that. Since GM came out with that trans model, all transfer cases were driver side drop, which won't work for our CUCV's.
ballencd
101
Columbus, NC
Maybe a divorced transfer case would work. The truck is long enough for that I think....?
The low first would make it easy to start out but I wonder if the power of the 6.2 would even push it on level road in 6th? I've only l run this engine with the TH-400 trans and it did fine in my M1009 but the M1010 is a beast comparatively.
6L80E
1800 RPM 2200 RPM
  • First gear — 4.027 9.92 12.012
  • Second gear — 2.364 16.9 20.65
  • Third gear — 1.532 26.07 31.87
  • Fourth gear — 1.152 34.67 42.38
  • Fifth gear — 0.852 46.88 57.35
  • Sixth gear — 0.0667 59.89 73.19
  • Reverse — 3.064
ballencd
101
Columbus, NC
From what I have read on other sites the 6 bolt P side drop case will fit the 6L80 transmission. I think it said you need to be sure your case has a 32 spline input and may have to cut the shaft off some but was fairly easy to do. I'm still looking. The only other alternative I have found is the TR-6060 manual. 1st gear in it can be from 2.5 - 3.0 range and the 6th is between .5 - .68. It does have a 1:1 for 4th gear but I'm not sure if that make much difference. It will bolt to the 6 bolt round transfer case too. No electronics is what I like on that conversion. You have to install a clutch assembly and they can be pricey but not more then the added computer for the auto. Yes the 4L80 makes the most sense but I am planning on traveling with my M1010 and need to do highway speeds.
chevymike
485
San Diego, CA
I was just watching a video on a guy who did a 2WD 6L90E to NP208 transfer case. The output shaft on the 2WD 6L90E was larger in diameter and 36 spline, versus the CUCV NP208 32 spline. He had machine shop reduce the diameter and cut 32 splines. I am not sure if this is an issue with a 4WD 6Lx0E or not.
I have the original TH400 with a Gear Vendor OD and 33" tall tires on my M1010. I can cruise at 65mph and can reach 80 if I am push it hard. Another option, might be a 4L80E with a GV unit. That would give you double overdrive BUT also gear splitting. Not a cheap solution but another option.
ballencd
101
Columbus, NC
From what I have read, the 6L90E has a larger shaft then the 6L80E. The 6L80E has the 32 spline like the NP-208, NP-241 and NP-242 and I am sure you could convert the NP-205 to work also but a bit pricier. A newer, not sure of the years yet, with VSS output might be helpful for the electronic controller...??? Of course with a manual you could jump start the vehicle when the batter was dead and there is no slipping even thought the auto could lock the converter. It's looking close to the same money but I have not gone deep into the pricing yet. I did get a quote for a new TR-6060 and it seems it was in the $8-9K range....ouch. Not remembering if that is with the bell housing/clutch/etc....not the pedals I'm pretty sure.
chevymike
485
San Diego, CA
Yeah, I was doing some more research on the 6L80E and yeah, it seems like it's the same size/spline shaft. Seems no method is likely cheap.
UNIMOG-GUY
Blacksburg, VA/Denver, CO
I did the whole 6.0 LQ4 LS, 4L80E, NP-205 swap for just the TR-6060 cost. Highway speeds aren’t a problem with a 4 speed when you ditch the 6.2.
Pic is from recent trip from VA to CO and no I don’t normally run the truck at 80 mph. I was curious what the RPM would be at 80mph.
ballencd
101
Columbus, NC
I'm thinking I would have bought a gas truck if I wanted gas besides my engine only has 19K miles on it but I hear you. The LS would be quieter for sure.
UNIMOG-GUY
I get it. My 6.2 blew an oil line hose and the engine locked up which then prompted my swap. However for where I live now (CO) and what I do (driving up into the mountains) with the truck now the 6.2 would be absolutely miserable.
ballencd
101
Columbus, NC
Mike, I missed this on the first pass for some reason. The CUCV's are PASSENGER SIDE drop for the transfer case. I'm still looking for a better highway speed and think something in the .65-.63 range would be best. Are you having any luck with an OD transmission? My wife wants it to be an auto but I am liking the TR-6060 with 5th of 0.80 and 6th of 0.53....but the 1st is only 2.66. Would have to add the extra pedal to swap to manual though. The 4L60 has a 1st of 3.059 and OD of 0.696 but the 6L80 has 1st of 4.07 and second OD or 0.667 which would be very nice if the controller can be worked out. I have not found a stand alone controller for the 6L80 yet.
chevymike
485
San Diego, CA
I haven't done more research as I am not even close to needing it. Currently I have a Gear Vendors OD with the TH400, so I have something but it's not as deep as I would like. The 6L80E would be a great combo, with the low first gear and deeper overdrive but yeah, not finding a stand alone controller.
cucvmule
collector of stuff
1,171
604
Crystal City Mo
Why not go with a 4:10 Ratio axles with what trans combo you choose. The 4:10 will still give you a better compromise with both ends and still give good towing capacity.
My 1982 Silverado K30 6.2 with 4:10 and M40-Turbo 400 has very good highway speed and will pull hills with 6000# on a trailer. I have 285 BFG All Terrains on for very good on-off road traction. Always wanted to go with the 700 but do not need tow long distances to justify the change.
And gaining how much MPG are you thinking to achieve with 6060 combination. The 6.2-6.5 is really limited on anykind of powerband in NA as is better with turbo but is constantly shifting to stay in the powerband worth all the extra gears? I think you will tire of it and the trans will also.
With the 4L80E manually downshifting to 3rd a little earlier than the trans wants to keep wheel speed up. With other overdrive options, trans and or Gear Vendors unit you will have many more combination alternatives that are easily attainable with off the shelf parts.
ballencd
101
Columbus, NC
The 4.56 axles should work well with either a 6L80E or a TR6060 without the need to also change the axles. Yes, a bit faster on the high endwith the 4.10 but I think a top speed of 85-90 is plenty for a truck this size. If I just change the axles i'd be getting about 50 mph in top gear with the TH400 transmission so I would have to change the transmission too.....added cost that IMO is not necessary. I did find a controller TCM-2650 that minght do the trick for the 6L80E transmission. I have e-mails the company to find out if it will work. Time will tell.
