Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Hello, I replaced the old digital headlight switch after it failed. I use a manual three lever switch. When I turn the lights on the running lights/ tail lights come on but no headlights? Are the headlights on a separate fuse?
Are the headlights on these trucks 12 or 24 volt? A guy is selling the LED headlights which are 12 volt and lists them for military trucks like these and the humvee and I know the humvee uses 24v headlights and I was trying to tell him most military trucks are 24v with regards to headlights.. Am...
A0 lighting ckt. Basically the same throughout the versions, with the exception of the brake ckt. On the A0 the pedal pressure switches provide a ground, in the A1s they changed to the switches providing DC power…
Probably not. The button lights switch is a powered electronic control device that consumes power so requires a return/ground path for its operating current to flow thru. The 3 lever is simply electrical contacts, so no ground required…
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
