M-series flasher relay - civvy conversion how-to
1,127
I just bought an ef22. Can i just run wires to under the dash and mount it there instead of using a gang box or such?
I suspect you mean an EG22 but yes. You can simply cut off your cannon connector, ignore the ground wire and crimp spade connectors onto the existing wires, if that's how you want to roll.
tcruwithme
20
Eagan, MN
Is there room in the new box for a second/spare relay? I see that Vetco has several size options for this type of box.
So, I have to post an update.
After 3 years on the truck, one of the plastic mounting tabs on the box broke. Now, this may be my fault, as I tend to pull the box off and use it to test customer vehicles before I build another relay. So maybe that had something to do with it............
But, after thinking about it, I think the heat and vibration of the engine compartment are probably hard on that box. So I ordered one of the metal boxes The Stig used to build his and I've now upgraded my flasher to Version 2.0.
View attachment 720322View attachment 720323View attachment 720324View attachment 720325View attachment 720327View attachment 720328View attachment 720329View attachment 720330
1,127
I don't think so. I think when i converted to this box from the plastic that I tried to move the extra flasher into it and it wouldn't fit.
The Stig (who I got the part # for this box from) used this one because the bolt holes allowed it to bolt to the vehicle using the factory holes.
Kickerson
Wilmington DE
Do you have a link or part number to the wires you connected to the EG 22? The wires can be seen in the pictures of version 2.0. Thanks for the post and has anyone verified that this will work with LEDS yet?
1,127
I don't have a link for the harness I bought, because I got it from Napa but I suspect this one will work:
https://www.napaonline.com/en/p/TWR3032BX
I have seen this work on a truck that had rear LEDs, incandescent fronts. That's my only LED experience.
MyothersanM1
19K M1 Armor Crewman
417
68
Culver City, CA
My third GI flasher unit in nine years has decided to go south me and I am now done with those problem children. Driving SoCal freeways with no flashers is scary proposition.
So, here's my stab at this upgrade on my M818. I did fudge up the on the "L" contact lead on the wiring harness. I was not getting power into the relay. I just reversed the red and black (open) leads and, BAM, "click, click, click..."!
The box mounting tabs were drilled out to 5/16" just enough to mount right up to the existing holes.
As you can see, a boxed up spare relay is stashed snugly inside. I also added some padding to prevent to much vibration.
1,127
My original EG22 that I installed in 2015 died at the rally last week. So I got about 4 years and 8 months. Not sure on mileage, but I don't drive the truck much.
Metal box had no moisture in it or evidence of having had moisture in it.
1,127
Well that's a shame. You have all incandescent lights right? Hoping I'll get a good long life out of mine with all LED signals.
Yes. Although all my civvy trailers have LEDs. I think this is just what you get with cheap Chinese stuff. I doubt it's a load issue.
Recovry4x4
LLM/Member 785
1,807
GA Mountains
So, I'm going to do this for Jonathan's M49A2C. As long as I can get the connector back in the cab, I plan on mounting this up under the dash out of harm and road grimes way.
cattlerepairman
3,237
NORTH (Canada)
Clinto, that is 4x the life span of the military correct flasher units I had installed. They were utter garbage.
Sent from my SM-G950W using Tapatalk
dherman304
53
Texas, DFW
Excellent post, (not sorry for reviving it) I did the mod and all signals work except back passanger. I checked voltage at the socket and it seems to be the same as the driver side socket that is working. I tried three different bulbs as well. Any idea what could be wrong?
19,518
You checked voltage...
Did you check the ground on that right rear fixture?
