- 1,038
- 1,903
- Colorado
No sense in putting $$ into a hydraulic or electric recovery winch on front or back that'll never get used. This is an M9-18b 30k Braden unit with the rope drums.Holy @#$% !
Thank youAlso you need to remove the front driveline and suggest you remove the cross bar to get better access
The stud alignment method works on other stuff. I had to do that on my Cat 3304 because it has a scavenger pan above the oil pan with a double gasket. The studs really make the gasket install possible.As I recall, there were two studs on the trans side that I hung the gasket on. I also used copper gasket spray to ensure a good seal. Of course cleaning the area first is a critical step.
How many men in an anchor detail?you are going to have to train an anchor detail to operate the thing![]()
I'm going to guess it depends on the anchor. And probably the boat?How many men in an anchor detail?
