- 5,263
- 4,001
- Charleston, WV
Hey guys,
Sorry I haven’t updated my M1152A1 build thread in a while. Got busy with some family activities this summer and slacked off. I will update it soon!
That said, I have been driving my HMMWV to work and around town some. The transmission seemed to be working pretty well after I worked some initial bugs out of it including replacing the TCM and repairing a bad wire to the check light. Recently, it has stopped going into OD and is a little slow going into Reverse (maybe takes a second or so). The shifts between 1-2 and 2-3 are nice and smooth, no slipping and fluid is normal in level/color/smell. Jumping the terminals on the test plug revealed a code 74, so I started following the troubleshooting section in the trans manual. The resistance on the TISS was in range, but I put a new one in just in case. Also, the wiring showed continuity between the TISS and the TCM. The only other issue I have found is some ATF in the connector at the transmission, so it looks like its seal is failing. The TCM is new. The wiring in the battery box all checks out. Grounds are good.
Anything else I should check? Could fluid contamination in the connector be causing all of the issues?
I hate to take it to a transmission shop, but I am not sure what else to try at this moment.
