Just got a m1082 trailer. Brake question.
Ned81
192
VA
So I just picked up a trailer from gov planet. Everything seems to work but I don’t understand what the push/pull valve does on the right side in from of the tire. With the truck is connected, the button is out and doesn’t stay out when pushed. With the truck disconnected, the button will stay in either position.
What’s it for? Is it functioning properly?
My thought is it is meant to release the brakes without the truck as long as the trailer tank still has pressure. ( it doesn’t do that) I searched the TM with no luck.
Ned81
192
VA
Thank you! That’s what I was thinking. Time to investigate.
