MEP-003a oil pressure sensor Specs
Rocketman007
Kannapolis NC
The oil pressure sensor on my MEP-003a has developed an oil leak.
Need to get a replacement sensor.
I can buy one online but need to know the specs of the sensor to make sure I get the correct one.
Wonder if auto parts stores would carry such?
Thanks
Jeff
rickf
2,240
Pemberton, N.J.
He is probably looking for the pressure open/close rating. But the price on that one you show is very reasonable. I will probably get one for myself.
Scoobyshep
2,188
Florida
Appreciate the information...
The sensor from Iron Wing looks like it will do the job... Price is reasonable also... so I ordered one.. shipping cost was the same price as the sensor, but that is what it is...To buy one locally at an auto parts store probably would be the same...
Modern problems of shipping. If you dont have it the 24p manual has all the part numbers you could need.
rickf
2,240
Pemberton, N.J.
Where do you go to find the part by NSN? I have used a couple of the big time NSN suppliers but navigation their site is a chore and while it does give the specs for the parts they do not sell parts. They show the vendors that the military used but that is no help to someone that needs one piece.
kloppk
4,170
Pepperell, Massachusetts
As previously posted all the part numbers for the set are listed in the -24 TM.
In the TM you can locate the OP switch and its "find number " 15 in the image below.
Scroll down and locate find number 15 in the parts list.
There is a typo in the TM. It should say 15, not 5 in the second column. The NSN is listed 5930-01-039-3140
If you then go to Parttarget.com and put the NSN in the search bar and scroll down you'll get a list of all the PN's that were used.
rickf
2,240
Pemberton, N.J.
Now that is good info there! I have always used WB Parts or NSN lookup and they were not as user friendly or listed as many suppliers.
