Headlight issue
Yellowfins
Florida
Chances of both headlights going out at the same time? I’ve put a tester on the wires and have low beam and high beam power on the wires. All connections are clean. I have the TM’s, just seeing if this has happened to anyone else.
Thanks
Mogman
10,434
Papalote, TX
Thanks
Do you by chance have a 60A alt? if so check your battery voltage when running
Yellowfins
Florida
Would the removal of the night driving /blackout light cause this issue? The light was unintentionally removed. The wiring is still intact though.
Thanks
Mogman
10,434
Papalote, TX
Thanks
Not likely, both high and low beams going out on both headlights would be extremely rare unless the voltage was way out of whack.
Did you test the voltage with the lights attached?
Mogman
10,434
Papalote, TX
What kind of headlights are they? if they are incandescent you can ohm them out, if blown then all terminals will read to infinity and beyond :LOL:
Mogman
10,434
Papalote, TX
Incandescent. Sorry im in sw Florida or I would have got back to you sooner.
Well then you can simply ohm them out, not sure what they should read but if they are blown you will get an open (infinity) to all the terminals.
