- 530
- 773
- 93
- Fort Lauderdale, Florida USA
Hey guys, i am here looking for help.
While on a trip yesterday to the Florida west coast to bring supplies the belt tensioner broke and the belt strings damaged the AC compressor (Sanden 1 wire)
The tensioner issue was resolved, however i was trying to fix the AC system with no prints available to me. First question is if anyone have prints for this system.
I will explain the issue and probably someone can help as well. I kinda fixed the stripped wires behind the clutch with skrink tube, and the red dot diagnostic is flashing 3 times which is check compressor clutch.
I measure the wires agains ground (both disconected) and it is not shorted to ground. The coil measures 19 ohms (not sure what should be) when i disconnect the wire from the compressor coil and i measure i assume i should have 24VDC and i got nothing.
I have to mention that the positive wire feeding the AC unit almost burnt and the breaker did not trip.
All this leads me to believe that the diagnostic box might be damaged or shorted as i believe this must provide 24VDC to start the compressor, unless i am totally wrong. I did not want to apply 24 volts durectly to the compressor as i am not sure how it works.
Anyone has an idea? Guides? Help? Will be very much appreciated.
