Antenna for VHF range HMMWV
blhar15
11
Waterloo, IA
I am looking for a VHF antenna that can mount to the standard HMMWV antenna bracket with the spring base that will work in the 100 - 170 MHz range or so. Most of them are setup for the 30 - 88 range. Any suggestions? Thanks
I want something with the spring base.
Mogman
10,488
Papalote, TX
Did you ever find anything?
They make a wide band antenna, I believe it goes from 30-512MHz if looking correct is what you want, for performance it is not allot better than hanging a dummy load on the end of your coax.
blhar15
11
Waterloo, IA
Yes, I did find one as you described, the RF-390 30 - 512 MHz. It has two connectors at the bottom for the low and higher frequencies. I have not installed it yet, so not sure on performance.
Mogman
10,488
Papalote, TX
Here is the spec sheet, so if the frequency you are operating on falls in the -6db of gain, which is likely as the higher frequencies usually have the best gain in these types of antennas, if your transmitter has 50W of output you will have the effective radiated power (ERP) of 12.5W and that is referenced to a 1/4 wave ground plane which is considered "unity" gain.
On the other hand if you had a +6db gain antenna which is common for amateur/commercial antennas then you would have an ERP of 200W
Also you will notice the SWRs are 2.5:1 @ 90-512MHz this will cause most radios to reduce output power significantly so that 50W transmitter may only output 20W, (this would give you an ERP of 5W) even worse at 30-90MHz
