1987cucv
- 19
- 3
- North Dakota
I'm not worried about the mounts for the towbar hinges/shackle mounts. They're made out of tonka tough shin wrecking steel.well it depends what kind of hinges they used on that type your pickup has..
beside as far as I perhaps understand it a lot of aussie truck dollies have their own passive travel inhibiter built into the hinges as theres practically no chains or hand-holding needed for a dolly's tongue to stay relatively horizontal on its own making it easy for a solo driver to back the first trailer into second trailer nearly anywhere - and yet the tongue still can move up and down as needed
Yes! and a PT belt for safetyMaybe paint it pink also?
I would hope so... on the other hand I did a lot of wartime stuff that wasn't exactly safe but it needed to get done.I think it’s ok. You see towbars set up like that all the time in wartime photos. Your 08 is looking real good btw, I really like that you have the cargo enclosure set up. That is a ton of scrounging and work.
Thanks. Yup its as short as it will go. Its a grow-er not a show-erDitto to NDT
Only thing I would add is too maybe collapse the bar to its shortest hole but I took a 2nd look and you might already be all the way collapsed.
Interesting. Do you have a source for that? TM 10867A-OR doesn't say one way or the other is correct. And all the images of HMMWVs are being towed in this fashion. Other vehicles like the 939 get towed with them flipped because otherwise they'd hit the bumper.Turn the feet over before you actually tow with it. I have seen pictures on this site of broken bits and all the TM’s say don’t run with the towbar feet upside down like they are in the picture.
Thanks for checking.OK. I just read through 4 different tow bar TM’s from the 1960’s to the 1990’s. They all say to put the “foot” curve up for towing with all the wheels on the ground. However, for the HMMWV only when lifting and towing they show it mounted curve side down as you have it.
