Humvee starter
BlkH2O-Jarhead
New Mexico
My starter stopped working. It tries but it sounds like the teeth are worn. I ordered a new one. I have a floor jack and a friend to help me install. Any tips on getting the old one out or the new one in? Thx for everyones time.
Mogman
10,504
Papalote, TX
Thank you. Sounds awful. Hope not. If so then I have to drop the flywheel to replace the flex plate?
On an automatic transmission the "flywheel" is called a flex plate, you would need to drop the transmission to replace, rotate the engine slowly while inspecting the teeth on the flex plate.
First remove the dust cover and see what is going on, if you see something post some pics.
m38inmaine
102
Maine USA
I spent 2 weeks at the NTC in CA at a maint. shop and all I did was change flex plates, they came to us with the cross over pipe already removed, we just un bolted the transmission mount, bell housing and slid it back and jammed a 3/8 drive socket to keep it spaced back just enough to get a wrench to remove the bolts from the crank. We did 3 a day, and there were no shortage of them, all had bad teeth in one or two spots.
