- 2,333
- 4,209
- Massachusetts
Yes, and the flashing circuit.Thank you kloppk,
So the tests as described only verify that the exciter, transformer and pot are functioning properly ?
If those tests pass the VR is getting everything it needs to operate but it has failed if there is low/no AC output.
If one of those tests fail, then that related circuit is likely not allowing the VR to operate properly.
edit: corrected now to not in last sentence.
