Enforced_Leo44
- 89
- 28
- Parma, Italy
Hi everyone,
For a while my gen 2 light has been flickering when at idle, the flicker was erratic. Did a bit of research and the first thing that came up as a cause would be the voltage regulator so I decided to replace it.
Got the part, took off and apart the passenger side alt, replaced the regulator and put everything back together. Alternator is back on the truck, went ahead and connected the positive terminal of the front battery and... it sparked and a good amount of white thick smoke came out of the alternator. Disconnected the batteries quickly, took apart the alternator again and found what caused the smoke, and that would be the solid core copper wire that goes from the regulator to the rectifier (I think?). The insulation melted off because when I tightened the regulator mounting bolts, the eye terminal of said wire shifted towards the alternator casing (of course I did not notice this happening) inevitably making it short out with the rest of the engine and chassis.
Re-placed the wire, making sure that it was properly protected, insulated and distant from any ground (i guess those are all synonyms), put it back on the truck and... the Gen 2 light doesn't come on when ignition is on.
So... I know that I probably f'd up the alternator itself, I'm gonna take it apart again and test all the internals, my real concern is wether I f'd up something else in the electrical system because of that short.
Gen 1 and oil light do come on, I did some research before posting this and read about the 10amp 24v fuse on the fuse box that could be blown, but I checked it and it's good (even though in my truck it's a 15amp, probably someone in the past had some beef with 10amp fuses)
Before starting to overthink all of this, I'd like to hear everyone opinion, did I just trash an alternator or could I have possibly burned something else up?
EDIT: some typos
EDIT: some typos
