- 17,365
- 25,653
- Burgkunstadt, Germany
As the suspense builds, the joy one feels when it at last gets tossed on the porch is immense!
Unfortunately, "Tis the Season..." & that joy could fade rather quickly ... if one looks at their Ring Camera, etc. and notices that a "Porch Pirate" made off with pkg's before you snagged them off your porch!As the suspense builds, the joy one feels when it at last gets tossed on the porch is immense!
They are a standard, albeit uncommon stock item, dash size 202. https://www.mcmaster.com/#9464K118 The bowl takes two.The shipment I'm waiting for is for the fuel filter and the seals that keep things dry in there.
So Napa has the filter, but the filter only comes with a gasket for the bowl, not the two for the thru-bolt...
Not sure, what am I looking for, and where?What kind of Electric fuel pump do you have?
I currently work for the Navy, was 20 years USAF, and I can tell you it isn't any different in those two branches of the military than it is in the Army. The books will tell you it's one or the other, but when you go to start the maintenance, you discover it's neither...Open the front door, left side. down low is the primary fuel pump. There are several different kinds. One kind was well known for loosing pressure under heavy load. When the set starts to die, is it a long slow death? Or will it shut off quick? Now, you are going to want to know what kind. Well, I have to look it up, and that might take a bit. But if its a longer slow drop off sounds like a lack of fuel problem.
The E1074 is an Airtex pump.I currently work for the Navy, was 20 years USAF, and I can tell you it isn't any different in those two branches of the military than it is in the Army. The books will tell you it's one or the other, but when you go to start the maintenance, you discover it's neither...
This is the fuel pump I have. The only markings are the ones you see. At least it's made in the USA.
In the second picture, is that another fuel filter there?
