mep 802
Light in the Dark
6,651
MA
Ray70
6,822
West greenwich/RI
Start with the dead crank switch, is it in the normal position? Next is the red emergency stop button pulled out?
Next is the 7.5A DC circuit breaker behind the control panel, is it pressed in?
If still no luck the next thing I would check is the CR1 diode on the PCB board in the back rear corner of the control cube.
Lastly is the Shunt on the right side bottom inside the control cube.
This is all assuming you have good batteries and they are installed correctly....
yeller 1
20
Auburndale,Fl.
Do you have the TMs downloaded for this machine? I think you might want to if not, to eliminate some of the 'simple' reasons why you might not have power at the control panel.
Thank you for information will start on this next week
yeller 1
20
Auburndale,Fl.
good batteries will try again next week thank you and steel soldiers for all the help,will give up dates soon
  • Like
Reactions: 98G
WWRD99
1,859
York Pa
No light or anything ,good batteries ,hooked 24v
Ugh...so when you turn the start knob to prime the fuel pump doesn't turn on and these test lights won't turn on? No guage lights?
