MEP 803A Low AC Voltage and Alternator not charging.
Medic1
13
North Carolina
Received and installed Kurt's VR and all is well there, quick shipping, great price and great instructions. Now on the DC charging issue. Voltage reading at the alternator is 23.88 same voltage at the slave terminal. DC amp gauge is slightly in the negative. I have pulled the alternator and am looking for somewhere local that can rebuild it. If someone has a good alternator to sell I would be interested in that as well.
kloppk
3,994
Pepperell, Massachusetts
I see you only have 111 hours on it (if it's accurate)
1) Have you checked fuse FU1 to be sure it's good?
2) Have you verified that the Exciter terminal on the alternator is getting 24 volts when S1 in in Prime/Run?
Failures I've seen in the alternators are:
- Failure of diode(s) on the diode plates inside the alternator (fairly easy fix)
- Worn out brush's (easy fix)
Medic1
13
North Carolina
F1 fuse is good and had good voltage at the exciter terminal. At the alternator shop now the diodes are bad, do you have a source for them?
Light in the Dark
6,533
MA
@Light in the Dark also has a contact for alternator rebuilding IIRC.
I have withdrawn my recommendation of this particular shop, not sure they are even in business any more. Had 3 rebuilt and put on the shelf, two tested bad still when I pulled them down to use them. Not happy.
I do not recommend anyone use Dave's Starter & Alternator out of Enfield, NH. They were a Prestolite listed rebuilder at the time, not sure if they still are. Too much time has passed since they were gone through, for me to lodge a complaint.
Stupid me expected quality work out of an authorized repair house.
2Pbfeet
1,208
Mt. Hamilton, CA
That's a bummer to put it mildly. Alternators aren't exactly rocket science devices.
