14V alternator harness..
Talns100
Israel
Hello, in the diagram shown below we can see a harness is connecting between the 14V stator and the regulator. It is also showing that the current is AC.
If this is the case and the regulator gets 14V AC why is there a rectifier connected to the stator?
The manual also says that the current is rectified so I don’t really get what is happening.
N1505 alternator + N3135 regulator
Mogman
9,808
Papalote, TX
That drawing is more representative than actual as the upper stator is not shown complete as there must be more rectifiers on the upper stator to produce DC, I assume the phased harness is used so the 14V source can be rectified and regulated independently from the 28V output.
It takes 6 diodes to form a 3 phase rectifier.
Talns100
Israel
It seems the 14v source is rectified at the regulator and not in the alternator as they say in their manual.
What is actually going on?
Mogman
9,808
Papalote, TX
This is what is "going on with the 28V stator, the diode drawn between the +28 output terminal and ground represents the 6 diode rectifier, if you use an ohm meter connected to the +28 output terminal and ground (the case) you will see conduction in one direction only just like the single diode drawn in the docs.
On the 14V side they are likely using SCRs in the rectifier instead of plain diodes to independently regulate the 14V tap, let me see if I can find a schematic of how that would look.
Here is an example of what is going on in the 28V circuit with the 6 diode rectifier being represented by the single diode.
The field in these alternators do not have slip rings and brushes as shown in this schematic.
Mogman
9,808
Papalote, TX
This is probably close to what is going on with the 14V side of the alt
On the 28V side the reg controls the field winding to control the 28V output on the 14V side it uses SCRs (or something similar) to regulate the 14V output independent of the 28V output.
The phase cable takes the three phase stator output to the regulator where it rectifies it and controls the voltage inside the regulator itself.
It does this by basically turning on and off the SCRs to control the 14V output.
This type of scheme is by far the most efficient way to regulate a three phase output, much more efficient than using a linear regulator after rectification.
An SCR is basically a diode that you can control using its third lead and are the three rectifiers in the bottom of the schematic.
