Input requested - MEP-802A/803A Radiators
Light in the Dark
6,434
MA
Ok so maybe 12-14 interested folks? If I can get a few more on board, I think I can make this a reality.
Light in the Dark
6,434
MA
Well at the present time, the aluminum project is dead. Perhaps it may be revisited in the future, but it just wasn't meant to be at this time.
I will say though that lady luck has shined a little light on my thoughts here. In the last month I have been able to secure the OEM units. They are NOS/NIB... I did not have them produced. I'd say this is just as good as having them made, without the lead time.
For anyone interested now or in the future, the info is up the classifieds. https://www.steelsoldiers.com/threa...2a-803a-88-20093-nsn-2930-01-367-0228.222526/
cbisson
298
NH
Just picked up 2 of these. They are indeed new old stock with the original packaging and the original inlet/outlet plugs from the factory. I hope I never need them but I am glad to have them in the parts stash. I have 2 802s one with ~600 or so hours and the other has never seen the field. Only had 6 hours on it from testing when it was built at Fermont. Has about 100 hrs now. All this to say I think they both have a LOT of life left in them if properly cared for. I'd hate to have to jury rig something in the future for lack of the correct parts. It would be difficult to cobble something together for a radiator in these things with the lack of space, inlet and outlet on the same side, and the way they mount in the enclosure. Very happy to have the genuine article new in box.
Thanks LITD.
cbisson
298
NH
On the subject of radiator/cooling system maintenance , how often do you guys think would be wise to flush the cooling system and add new coolant in an 80x? I do know that the additives in coolant lose their effectiveness over time etc but I'm not sure if its related to use or if it just times out. Did the military have a periodic maintenance schedule for a cooling system flush and coolant replacement?
cbisson
298
NH
What gen set? Look at the LO for the gen set that you are thinking about. And also keep in mind that there are ways to test coolant to see if its still good.
Thanks Guyfang. They are both 802a's. I checked the LO, the -10, the -24 for the set, and the -24 for the engine and couldn't find any info on coolant flushing/replacement intervals. I did find specs on the type of coolant to use though. When the weather warms up a bit I'll flush them out good and fill them with new coolant.
