williamh
- 699
- 93
- SanDiego Ca.
I’m going to look a one and wondering what I should be looking for ? Other than running and putting our volts
I’m trying to find all the “bad” stuff to check for when I do my inspection.I'll add just this as I'm no expert...
The TM's really are extremely good. They are however, enough to cure the worlds worst case of insomnia. If you're not used to the way the military wrote manuals, it takes some getting used to. I'm just finally getting comfortable with the 802a manual after having to replace half my wiring harnesses...
As Guyfang said, find out specifically what you're going to look at, beyond just the 802 aspect. Read as much as you can take from the archives here. It's easier in some cases to understand things when you're reading a post from someone else that doesn't know what they're looking at. The guys here are amazing at helping you understand things, but getting that base level is a steep climb.
Biggest thing is missing parts. Many units have been decommissioned because maintenance removed a switch or pump. The other common reason for decommissioning lately is fuel leaks from the return lines or the injection pump feed lines. Both of these are easy fixes and no reason to avoid a unit.I’m going to look a one and wondering what I should be looking for ? Other than running and putting our volts
