- 10,868
- 768
- Appomattox, VA
So I have completed my move to the new location, and getting set up for the next MV project which is refurbishing the CUCV 1009 I got from Scrounger's estate. A noticed several of the fittings where the antenna mounting brackets go into the side body sheet metal are either seized up (can't remove the bolts for the antenna bracket) or they spin when I try and remove the bolts. Not sure what these things are called, or where I can get them.
Anyone have any experience with replacing these fittings? The condition of the rear quarters are not too bad, a few creases, not sure if I should cut these out with a torch and replace the fittings, or cut out the entire sheet metal area and patch it with a new panel.
