mep 002/003 fuel tank replacement
Dog Breath
154
33
Wisconsin
Has anyone had any luck finding a plastic tank replacement for a 002 or 003 generator? Or a suitable replacement that is reasonable? I was going to cut the bottom out of the tanks i have and weld a new bottom on if i can't find anything that will work, but it might be a PITA.
Scoobyshep
2,188
Florida
What is the root cause fir replacing it? I have seen some people make a custom tank as a replacement online.
Dog Breath
154
33
Wisconsin
the bottom of the 3 tanks have rust holes. One tank has multiple rust holes. I can weld patch holes but I am thinking that one hole leads to more down the line
Scoobyshep
2,188
Florida
Fair, there are off the shelf coatings that can be applied internally , but it sounds like the horse has already left the barn. I dont have an off the shelf replacement, but my welding skills say I can make one. (ive also been known to weld holes up in tanks from time to time)
Dog Breath
154
33
Wisconsin
I am leaning towards cutting out the bottom and welding in a new piece..the wifey isn't the happiest parking outside because 3 -003a are in her side of the garage..LOL
I have one tank that has a coating that is bubbling and lifting, probably from the degreaser i had to use to get out the tar in the bottom..OOPs
Light in the Dark
6,758
MA
If it were me, and the machines were important to me... I would just find an aluminum tank that can be mounted in its place and dump the porous steel forever. Either drop in (smaller) or custom... I think it would be worth it for me. Of course in the mean time you could always rig up extended fuel lines (fill and return) and run off a freestanding tank (provided you set it up to accept the return).
Dog Breath
154
33
Wisconsin
I would love to but the prices are a little out of my budget. If my aluminum welding skills were better I would attempt to build tanks myself. Although I would probably be pretty good after the first tank
Chainbreaker
2,112
Oregon
If you search on eBay for "aluminum diesel fuel tank drifting" you should find some "interesting aluminum tanks" that might be modifiable for genset usage. Though you would have to somehow adapt or remove the fittings they come with. However, the prices for the tanks themselves seem quite reasonable as a potential platform to start with... Just a thought.
