Fuel Plug Retrieval
GMVguy
116
Texas
Welp, I went to drain the old fuel on a recently-delivered truck and the plug was so brittle that the outer lip came off and the plug went into the tank when I tried to remove it. Got any recommended tools/procedures to fish out the plug without dropping the tank? Currently looking for a pair of needle-nose pliers or something similar that will get in there through the drain plug hole and grab it.
20,817
Maybe a "grabber" kind of thing? With that four fingered claw on the end of it?
20,817
Unfortunately it does not… Has anyone added the access panel without dropping the tank? Would take some precision cutting, no doubt.
If you decide you want an access port, they are available. Might be worth a look on ePay. I only found one seller and he is currently out of stock. Found two more options:
Sells for about a hundred bucks. Kinda steep for a piece of sheetmetal, but it does beat lowering the tank to the ground to get a bigger hole to get something out of the tank that might not matter.
GMVguy
116
Texas
Yes sir, that looks like an absolute must if and whenever a fuel tank has to be dropped. I bookmarked this thread for when I inevitably do:
TNDRIVER
579
Cleveland,TN
Everyone is correct about leaving it and I suggest you only replace it with the "real" replacement part with the screw in the center.
My 2 cents for what it's worth.
GMVguy
116
Texas
Yes sir, already got the OEM Plug. Now I have an open afternoon to replace the transmission filter. Thanks all!
