MEP003A Rectifier Board Burn Up
screejunk
10
Vermont
Starting a new thread for this issue.
Hello, we have a similar issue with rectifier board burning up, including a new one:( We have installed a new master switch and we have checked the diodes. Our tech, who is amazing, is still scratching his head... Is anyone aware of other points of failure to check to prevent the rectifier board from burning up? Any help is much appreciated. THANKS
We did check this useful information:
There are 2 diodes in the A1 assembly, which is located in the control box, where the gauges are located (upper right corner). These 2 diodes, control the current to the rectifier board. If they fail, current will continue to back feed to the board and burn the resistor. It took me 3 weeks to figure it out. The diodes are between A1-5 and A1-6 ; then A1-7 and A1-8. If you take those wires off and test between them you can check the diodes without taking the panel completely out. The diodes are tucked behind where you can't see them. Also this will cause the starter lockout not to function and your starter will stay engaged without ever letting go, burning the starter up.
We also installed new master switch.
Just wondering if there are other issues that can cause the resister to burn up. We are using the new Klopp version of the board and he has been very helpful.
THANKS
Guyfang
27,065
Burgkunstadt, Germany
Kurt and I talked about this, shortly.
1. You changed the old one out because it was also burnt?
2. You are 1000% sure you wired it right?
3. Did you ever see the set work right?
4. Have you, (or someone else) made any other repairs on the set of late.
5. Have you pulled the AC output box off the set and compleatly checked every wire and connection? Looked for mice crap and chewed wires? Worn wires?
6. Inspected every component to make sure that nothing is damaged?
7. The master switch should have nothing to do with it, but to exclude it, you have checked that its correctly wired? If it were me, I would just unscrew all the wires and re-hook them up, being very, very careful to make sure its right.
8.Have you checked the VR? All the wires on it. It can be hooked up wrong. I know all about that! Is it a Military VR? or an aftermarket VR?
tmoody
24
Mobile, AL
Did you get your unit running by changing the 2 Diodes on A1 Assembly? My original rectifier burn up, bought new Klopp Version, it made power a few seconds & burned up the resistor on the new board. Looking for any updates. Thanks
Guyfang
27,065
What you should do is start your own thread. This one is two years old and never completed anyway.
tmoody
24
Mobile, AL
I believe it is Jim, in the weeks leading up to the issue all was working well with cranking/shutting down. Physically, the switch feels good like it is supposed to; not to say something could be going on electronically in the switch. I have a good fried that is very experienced in electrical field, I am sure we can test that. Also cstumpf 750 mentioned testing the windings. I have a new resistor coming from Kurt for the new board & I located the 2 diodes mentioned in the A1 assembly. None were not very expensive to change (Will save the original for spares if they test good). If I find the root cause of the issue, I will be sure to post for others. Thx All who replied so far. Terry
Ray70
7,084
West greenwich/RI
I believe Jim was talking about the centrifugal disconnect switch located under the little tin cover ( held on with a small wing nut ) to the right of the oil filter.
This is the mechanism that disconnects power from the starter motor whenever the motor is spinning more than ~600 RPM.
This is what allows you to continue holding the main switch in the crank position after the motor is running ( while waiting for oil pressure to build ) without grinding the starter motor.
tmoody
24
Mobile, AL
Ray70, Thank you for the clarification, I got the repair manual out last night to study it. I looked this morning & see the cover you mentioned (Tiny Pic attached). I have not noticed this before but I’m on it now!! Makes perfect sense that could cause something to burn out. It will take a little time for me to follow this through but I will 100% check & report back.
Ray70
7,084
West greenwich/RI
That's the one! Its very easy to test / verify.
When you start the machine, if you have the old style starter with the external linkage for the bexdix, when the engine first starts, watch the linkage while you continue to hold S1 in the crank position. You should see the starter gear disengage even though you are still "cranking" the engine.
You should also be able to turn S1 to the crank position at any point while the machine is running and the starter should not engage if the S7 starter disconnect switch is functioning properly.
If you find that it does not disengage properly the adjustment procedure is pretty simple.
tmoody
24
Mobile, AL
I do have the old style starter, the linkage disengaged as it was supposed to. After it was running, I turned the switch to start again, the linkage didn’t move. Apparently that part is working as it should. Glad we were able to mark that off the list. Thank you for the Pro tip.
tmoody
24
Mobile, AL
Hello all, last week I took the generator to someone who knows how to work on them and left it. It will be several months to go get it due to the distance but I will let you guys know the result. You tried to help and I appreciate that, this issue is above my abilities but I can pay someone who is capable. Thx
