First load test MEP-803
cstumpf750
13
The Jersey Shore
I did a 1 hour load test with two 5kw 240v heaters I got from Amazon for $65 each. The thermostat is still working after it stuck closed on the first run. At the end of the hour, my oil pressure was 55psi on the gauge. With both heaters, I showed 76% load. An ammeter showed 34.5 amps per leg. No smoke other than on start up For a few seconds. I have a third heater coming so I can do a max load test. but so far I’m very happy with how it runs and performs.
20,594
Yeah! Good Deal.
Happy to hear that you made it through the first run...
cstumpf750
13
The Jersey Shore
Another bit of information, this generator came from a batch that were reset and sold out of Chambersburg, PA. It’s a 1994 Libby MEP-803A with two hours on it. They seem to sell a lot of units like this at that location. According to the paper work the reset was done in 2013 and included a new at the time trailer. It appears to have sat in storage till they auctioned it off. So if someone is looking for a good unit, reset units out of there are a good bet.
cstumpf750
13
The Jersey Shore
Full load test successful. At least a short one. I warmed it up and progressively added load, letting it sit for a minute or so each time. 124% load. Only a tiny bit Smokey above 100%. I plan to do a long load test when it is hot out, but at this point I have good confidence in the reliability of this unit.
