MEP803A - 0W40 Oil
vrzff
97
Mont Vernon, NH
Hey all,
Just wanted to make a quick post for the northern people here. I started running Rotella T6 0W40 in my tractor to help with the cold starts, and also changed over the 803A last week. Note that this is a "heavy duty" diesel oil, and not a European car oil (which does exist).
While it's not in the book, a 0w40 oil is still a 40 weight oil at operating temperature-- same as a 15w40. It has a lower viscosity when cold, which reduces wear and allows easier cranking. While I cannot prove wear reduction, I can firmly say that cold starting is significantly easier. The cranking time has dropped to a few seconds, down from 15+. Protection / proper lubrication is rated from below -20F to 120F+, it's essentially a year-round oil.
I'll be doing an oil analysis every 100 hours, and report back to this thread with the results. The main thing I'll be keeping an eye on is the viscosity at operating temperature, because the viscosity modifiers (which allow the oil to change viscosity) can and do wear out with use, resulting in a thinner oil at operating temperature.
vrzff
97
Mont Vernon, NH
Slow going on the hour clock.
A series of snow storms and cold-ass weather has kept me mostly indoors-- aside from rebuilding my snowblower's auger gearbox from using anything and everything as a "shear" pin. Turns out that old drill bits work great, because they don't shear; the little brass gear does instead. Then I decided I needed a headlight too, because wouldn't that be convenient. Swapped out the flywheel with another model (which has magnets), and added a rectifier / regulator to make the LED driver happy. Also added an impeller kit, which is basically rubber scraps that close the gap between the impeller blades and housing so that you can blast snow into the neighboring lot. Good for shooting slush too. Now I wish I got the 6 amp wheel, because who wouldn't like heated handles and a second work light. I'll have to post a few pictures of the light project. No pictures of the gearbox because it wasn't a pleasure project, more a get it the **** done thing.
I did get a chance to do a five hour run this week. Had to swap out my house meter panel, so I fired up the generator to keep the power on after the utility pulled the cutout on the pole so that I could work. The line guys came over to see it running and loved it. All kinds of questions, opening doors, and looking at the gauges. 1800RPM is like a magnet for certain people.
All this snow up here and the power didn't go out once. It's so disappointing. I've been waiting for a week-long blackout like last year to justify my purchase with the wife-- who doesn't think highly of it (or the tractor.)
Chainbreaker
2,112
Oregon
You'll find that once you have a supply of generators on hand, the utility power will never go out again! I used to loose power 4 or 5 times a year.
Started buying MEP's about 10 years ago and I don't think we've lost power for more than a couple hours since!
I can totally relate to that :D! When I bought my 1st genset a MEP-002a we routinely lost power every winter multiple times and I needed to keep house water well, pumped-septic system, propane heat all powered on & wife happy etc. Then I later bought my second genset for our other service entrance at Shop/Barn for backup power there as it has separate well & a pumped septic system as well & also with horses to keep watered & lights on. Now being more prepared/ the "pwr outage gremlins" sensed my outage preparedness & seemed to skip to every other year outages. When I bought my 3rd genset as backup for genset #1 the local power failure demons seemed to pull a fast one & switched to causing outages during "summer fire season" due to increasing frequency of dry conditions increasing & high wind "preemptive utility shutoff's" during high fire conditions .
I then decided that in order to implement the "2 is 1, 1 is none mantra" for mission critical outages (keeping wife happy) I then had to have a matched set of 4 gensets (2x at house / 2x at shop/barn). Well parts started getting a bit scarce for these older generation units, so I also bought genset # 5. Then with summer fire season outages increasing I needed a MEP-003 10kw (genset #6 ) so that I can run the AC at house during any hot ♨ summer outages to keep wife happy & also to also keep my cool during somewhat stressful fire conditions.
Unfortunately, :confused: the new to me #6 unit -003 is a work in progress now waiting until dry spring/summer weather to resume troubleshooting/fixing the "total engine run-away rolling coal belching beast" 🌋 🚒 that it unfortunately turned out to be. :sick: However, with no outages this winter so far... the "outage gremlins" are apparently in winter hibernation & just might awaken for summer torture testing outages I'm guessing. Once I get genset #6 repaired, the outage gremlins will hopefully decide to move on and find someone less prepared to victimize!
