FLU419 SEE HMMH HME Owners group
glcaines
2,807
Hiawassee, Georgia
I replaced the compressor head with a new one months ago and it appears to be working fine. However, you never know. I guess it is possible that the new head isn't working properly. Although the pressure regulator is holding the pressure at 106 PSI, it could also have an issue, as well as the alcohol injector. I need to do some serious troubleshooting to narrow the problem down.
Turns out the problem is with the unloader. I found a replacement on Ebay for $58.80 with free shipping. Hopefully I'll receive it soon because I have a project that needs the jackhammer.
glcaines
2,807
Hiawassee, Georgia
I had one give up on an HMMH.
Paid something like that, too. And they're easy to change. Forgot all about it until reading your post above.
Actually, the one that failed on mine was replaced by me several years ago. The model # I purchased for both is: WA9753034730A. I hope my new one holds up better. After removing the failed unloader, I noticed some corrosion in the steel fittings between the unloader and the crossover tube to the air tank. The crossover tube was previously replaced by me with a 316 SS 10 MM tube, so obviously no problem there. I like permanent solutions, and that 316 SS tubing was a permanent solution.
glcaines
2,807
Hiawassee, Georgia
Now that I have the air pressure issues resolved, I need to attack the problem that my alternator isn't charging and the tach, which is fed by the alternator, isn't working. Although the TM says I must tilt the cab to access the alternator, I seem to remember a post, either on SS or Benzworld, where someone was able to remove and replace the alternator on a FLU419 without tilting the cab.
brandan34
46
Southern Oregon
I do not know the post, but I have done it. I installed a new alternator while cab was off, only to later find i wired the voltage breaker thing wrong. I had to remove the alternator to figure it out. I may have had the front of the cab lifted a few inches at the time, but I am fairly sure I did it while the cab was on all mounts. Either way no cab tilt was needed.
The FLU farm
1,497
The actual midwest, NM.
Maybe try replacing the regulator first?
That's fully doable without lifting the cab. Not fun, but even I managed to get it done.
glcaines
2,807
Hiawassee, Georgia
Actually, I put a post on Benzworld about the problem. Several people responded and told me to check the charging warning light bulb. They said that voltage from the bulb goes to the alternator and is required to activate the alternator. My bulb checked out fine, but when I re-installed it, the alternator started charging and the tach started working. Apparently, there was a poor connection with the bulb. I had no idea that a faulty bulb could cause that problem. I am very happy that I didn't try to remove the alternator for repair.
Another Ahab
4,941
Alexandria, VA
Same problem a few days ago. Jam lever in the up pos then handyman jack did the trick for me. Once up set the things on the lift arms to hold it up.
My part is different than the one above, but does work. The belt that I copied I think I got from EI. Anyway just make sure the belt you get is a stronger kind.(not fractional horse power. Learned that the hard way.)
That's a B****. But once you learn something that way, you'll never forget it!
Knobby57
64
Pa
I'm still in the middle of replacing the head on my compressor. I removed the old head with the wheel still in place which was not a difficult job. However, the new head I received from Estonia came with a much thicker head gasket and additionally a gasket to go between the cylinder and engine block, which the FLU 419 didn't have initially. I need to remove the cylinder and clean the sealing area on the block and also on the cylinder. It is virtually impossible without removing the wheel. I can't get any of the lug nuts loose to remove the wheel. I've use a 1/2 inch impact, a 3/4 inch impact and finally a 1 inch impact wrench. No help. I put a 3/4 inch drive impact socket on my 3-foot long torque wrench and none would come loose. I finally put a 2 foot long piece of pipe on the end of the 3 foot long handle on the torque wrench. I sheared the Chinese impact socket in half! My wheel is still on. Some of the lug nuts are now somewhat damaged. I think the next step is to heat the lug nuts with my acetylene torch. I've ordered new lug nuts, but haven't received them yet. It wasn't me that overtightened the lug nuts!
I may be a little late to this game, but I believe the gaskets on the compressor pump, a different thicknesses. There is a tolerance that needs to be kept I believe that I did read that in the manuals
glcaines
2,807
Hiawassee, Georgia
You are correct. However, my new head came with a slightly thicker gasket and instructions that it would work for any situation. I hope it was correct, because that is what I did. So far no problems.
brandan34
46
Southern Oregon
Anyone ever have the rear axle torque tube break off of the rear axle before? I was yanking a guy out of a ditch with a kinetic tow rope(38k pound bungee cord) hooked to the pintal hitch.. I did not feel like I was abusing it as I would let the clutch in once I hit the end and let the rope and brakes hold the force. That said when I got back home all but two of the bolts on the torque tube had pulled out of the rear diff and the bolts that hold the rear springs on and stripped. I know those were on tight a few weeks ago. Never had cause to notice them since. Anyway I will post pics from my phone here in a few minutes.
When looking at the photos what all would you replace? If I can find it I am tempted to replace that flange at the end of the torque tube and otherwise clean everything deburr the worst of it, maybe rebuild the top of the rear diff with some belzona, retap all the holes to the next size bigger but otherwise just put it back together. What do you guys think? Bad move, should I just replace all the gears in sight? Yes they got damaged, but very little damage on the part of the gear that actually touches other gears.
brandan34
46
Southern Oregon
Pinsandpitons
66
Central Washington
yikes! To my eyes you would be silly to try and put those gears back in service. Maybe you could save the housing but the torque tube is toast and a complete axle would probably be the cheapest if you could find a donor mog. Bummer man, I'm going to look at my tube/diff bolts after this.
glcaines
2,807
Hiawassee, Georgia
I live a good distance off of the paved highway on 40 acres in the Blue Ridge Mountains in North Georgia. surrounded by National Forest. The road is mostly rock outcroppings mixed with gravel. There were two very hard gneiss rock outcroppings that stuck up almost one foot and about two feet in diameter, both being part of very large buried boulders. My military vehicles had no problem, but I've been driving my Tesla Model Y around the rocks and finally got tired of it. I decided today to go out with my FLU419 and use the jack hammer on the rocks. It took me about 4 hours but the jack hammer finally got the last of the rocks. The jack hammer that came with the FLU419 is fantastic, but extremely heavy. I'm 75 years old and that thing just about did me in. I almost couldn't lift it back into the cabinet. I've never used the rock drill, but I have used the hydraulic chain saw. That saw will really cut wood! I was really lucky in that the place that sold me the FLU419 several years ago told me it didn't come with any of the hydraulic tools. I purchased it sight unseen, only photos. When it arrived I was very pleased when I cut off the padlock and found all three hydraulic tools and all bits. The rock drill was brand new and still painted orange. The FLU419 had just come back from Afghanistan. Papers under the seat showed that it had also been to Kuwait and Iraq.
Migginsbros
7,658
Berlin-Germany
Perhaps it have do do something with the axel lock.:unsure:
If you turn on paved/non slip road with differential lock shifted in, you can brake the axel shafts, roll over your truck or explode the diff. Special with the heavy weight of the backhoe on the rear axel.
