M998 RIGHT REAR CALIPER LEAKING
Iambiig
24
Jackson, New Jersey
Coug
4,676
Olympia/WA
My Bad, it was an M998 1989 s/n 58689. From the parts manual, I think it is 57K3512 for the kit, and 12176301-01 for the caliper. Was hoping to get that confirmed
The kit part number you listed updates to the one I listed, so yes, that is the correct part number.
If you need the spring with the kit it is different for each side, but same overall cost from the above site
(in other words, there are 3 kits for rebuilding the rear calipers, one specific to each side with the spring, and one without the spring that works for either side)
When looking up parts it is better to use the NSN number listed in the parts manual, rather than the part number listed, because commonly the part number is only the part number from a single vendor, where the commonly stocked part number might be from a different vendor, but still identical parts.
Example below of the right rear caliper info for serial numbers below 300xxx
(I use PartTarget.com commonly when looking up part numbers because it does list all the different vendor part numbers)
As far as I can tell, most of the vendors are selling it with the AM General part number, rather than the Kelsey-Hayes number from the manual.
