Just saying I feel let down! After reading 11 full pages of this thread I was thinking I was going to be reading here in the end how the end product worked and a list of parts for us all to benefit! LOL, However I did find a ton of info I am very grateful for! Thanks all.
This month I will have had my M813 for two years. Still very much want a dual circuit brake system.
The below site looks to be a good place to find the variety of parts for the following:
The Bosch Hydro-Max brake system operates off of power steering pump pressure, and has an electric backup motor to supply you with brake assistance in case the engine dies. The Hydro-Max has come OE on most medium trucks since the mid 80's, that aren't full air-brake, including school buses...
www.powerbrakeservice.net
From this thread I will be looking for:
1. Freight liner Hydro max unit with 50/50 proportioning (Has the Pressure differential switch to notify a warning light letting you know there is a problem, and it has a low level brake fluid sensor. See post 125 on page 7 for details)
2. Custom mount for a 2nd Stock style NHC250 Power Steering pump which I already have.
Note: I have no idea how I would get belts onto this second unit seeing there may be a need for the belt to contact more than 1/4 of the pulley to not slip when under max load.
3. 24V emergency motor for the Hydro max unit, may need the positioning adapter used in these pages, but I am hoping not to as my assembly would be mounted to the firewall not on the frame where the original air/hydraulic unit is in this thread. HOWEVER that could change
4. Firewall mount Wilwood pedal assembly or similar (I would be getting the double peddle 7:1 mechanical advantage unit and using the 2nd peddle to install a hydraulic clutch assembly which would remove the "flex play" out of the stock linkage that annoys me when wheeling when the body and frame flex independent of each other.
5. 2" bore Master Cylinder with large reservoir.(The M813 5 ton I believe has larger wheel cylinders than the deuce and I am thinking this is going to be needed for the extra volume. However if going to disc brakes and using F750 calipers, this could be better at 1 3/4 perhaps. Still need to research.
6. Dual circuit proportioning valve External to the Master cylinder. I am not sure if this will be needed as the Freight liner MC unit is supoto take care of this so this will need more research for me... (50/50 seems best to match stock feel to the brakes)
7. Flexible brake line hoses from proportioning valve/or MC to frame rails as this M813 flexes like no other and the lines cannot be hard lined down to the frame.
8. Trailer brake mod to keep trailer brake function if I actually ever get a trailer. I already have a hand operated trailer air brake arm, which is intended to be mounted on steering column. to manually engage the trailer brakes. From what I understand this device is to manually engage the trailer brakes by themselves if desired. I was thinking this could be used to keep some way to have air brakes to a trailer. Since I do not own a trailer this doesn't seem very important at this time but someday who knows maybe I will.
9. Residual pressure valves for the brake lines. This is again a bit of a grey area as disc brake systems usually have these but any of my drum brake systems did not, but in this case it appears the Precision Re builders who are the experts leading most of the hardware options discussed here were thinking this is the right direction to go with 15lb residual pressure valves, one for each line.
Homework items, :
1HW: Seems important to know the Master Cylinder bore size on the original air/hydro-unit for the M809 series just to match that with the HYDROMAX bore size seems like a good way to go.
2HW: Anyone know what the stock PS pumps on the 809 series put out in PSI and volume? Should ensure this volume and pressure are compatible with the PSI that will be created to ensure we can get a "stock" pressure at least to the brake cylinders. On one post the psi was stated to be about 1500psi:
Hi Rusty, I will back up and list what I have, then my ultimate goal... On my M135 I have acquired the following: B700 Rotors F550 Calipers HydroMax master. I will be keeping the 4 15306 brake wheel cylinder brakes on the rear as stock. Ultimate goal...
www.steelsoldiers.com
3HW: Important! I have not seen anywhere in the discussions here what type of brake fluid is to be used. Our rigs use DOT 5 which is silicone based. These Hydromax units use other types. Anyone have any info on how this is addressed? I would think I would run DOT 5 still.
@jesusgatos how did you fix this?
On my M813 I would totally want at the same time to swap to disc brakes. All dreaming here. From what I have researched the F750 10 stud discs with the 4 piston calipers look like a solid fit. To do this mod I would flip my rear hubs, run long lug nut studs through the disc brake, then through the hub. I would then bolt/weld some caliper mounting plates to the axles. This way the disc and caliper will be tucked up inside the wheel and out of harms way.
A bonus from flipping the hub, is my rig with HEMTT wheels on all 6 tires are inset in the rear. Normally people put them on just the front axle to keep 16.00R20 tires from hitting quite so much on the steering box cover due to their 1 1/2 or 2" offset from stock 5 ton rims, but if you run them on all 6 the fronts are offset out from stock and the rears are inset from stock giving the rig a narrower rear tracking of the tires. I would prefer a wide track in the rear as well so flipping the hub is desired.
