Best Way to Repair Bed and Floor Damage?
NDT
7,432
Camp Wood/LC, TX
Ugh. 3 ways. Replace floor by removing 1000 rivets. Swap body with someone “parting out” a truck. Plate over it with aluminum plate or the GMV WB3 floor material. (RWH might have this on a salvage truck)
TOBASH
3,942
Brooklyn, NY
Go under the truck and tamp it out. You can Aluminum TIG or MIG… Or use thin strips of Aluminum sheet on the underside to repair, using auto body epoxy from the underside with self tapping screws to hold in place. Then grind off the screws and Rhino line it.
Alternatively, go to Tractor Supply and purchase a thick sheet of horse rubber and cut to size to cover the area. Then forget about it.
65grendel
Florida
Does the Rhino lining do a decent job hiding any imperfections or would I need to really grind and fair everything perfect first?
TOBASH
3,942
Brooklyn, NY
This is the flatbed in a truck and a used truck at that. I’m giving you instructions on how to get your truck up and running. If you are trying to make it look beautiful then you will need to drill out all the rivets and insert a new bed.
If you want, I’m certain you could do limited bodywork in the area, however the first time you throw something heavy on it the bodywork will crack
65
49
BOSTON,MA
I got this texture on my first attempt. Monstaliner. I think the move is to split it up into smaller sections. You can mix it in smaller batches. Rushing through the whole truck is gonna look like a mess unless your spraying and did a 10 out of 10 on the masking.
biscuitwhistler37
1,218
Michigan
With damage like that, I would get under the truck and push/pound/bend/pry the bent metal upwards, cut the pieces off, sand/grind the holes smooth, then lay a piece of 3/16 steel sheet down and self tap the squawk out of it, using shorties so as not to hit anything below the floor.
If you want it done easier and cheaper, that nice horse rubber mentioned above works wonders.
Had a Ford van with a big piece of floor missing, laid a sheet of 3/16 down and covered it with the rubber, never had an issue.
TOBASH
3,942
Brooklyn, NY
Respectfully, I think you mean aluminum sheet because in your Ford the bed was probably made out of steel and you would not get a galvanic effect using steel, but in these vehicles, the floor is aluminum and as such, you will get a galvanic effect unless you use aluminum sheet
biscuitwhistler37
1,218
Michigan
Even better, probably cheaper and definitely lighter! Thank you for the correction.
65grendel
Florida
you didn’t spray that? What did you use, a roller? It looks great
monkeyz47
Wisconsin
Roller job. Used the provided roller. Hopefully it lasts. I can't imagine stripping a whole car covered in this stuff.
I also used a roller when I painted my Jeep TJ with Monstaliner. It's held up well for 8 years. I used their 'pass the bubbly' tint for the tan color. It is tough stuff as long as you scuff and clean before painting. I also recommend not doing the entire mix at once.
NDT
7,432
Camp Wood/LC, TX
I am using it sparingly. Go overkill with this and your screwed.
Oh I fing sure can, takes a fing week with a torch to heat the metal enough to get the shit to come off with a putty knife. Did I mention I hate bedliner?
TOBASH
3,942
Brooklyn, NY
“Did you or a loved one heat up CARC painted surfaces and were exposed to the fumes, and are now suffering from pulmonary carcinoma? If so contact our law firm!!!”
He asked me how to fix the HMMWV, not his lungs or his life.
He can use airplane paint remover.
Specifically, to repair previously worked Aluminum, one needs to heat it.
  • Like
Reactions: NDT
