LMTV registration in WA state
rcamacho
914
Bainbridge Island Wa
Considering picking up an LMTV in the near future and wanted to check more current info on the relative gymnastics needed to successfully register one in state.
Ronmar
8,174
Port angeles wa
I had no gymnastics whatsoever in Port Angeles just a few months ago. Took under 10 minutes with the EUC paperwork from the auction for my 1079.... It will get registered as a "commercial vehicle, not for commercial use" and a 4 wheeler will have a max 26,000 GAVW... Not sure if they uprate a 6X, but i suspect they may not. they look up the vehicle model info(M1079, ect) from the EUC for that part, as well as the vehicle description
What truck are you looking at getting?
rcamacho
914
Passively looking 👀 at 1079’s. They are generally hard to find and comparatively dearly priced.
GeneralDisorder
6,030
Portland, OR
Getting more expensive by the month it seems like. Paid $43k for my late A1R and recently 1078 A1R cargo's in good shape are fetching $65k. I would expect M1079's to be between $35k on the A0 side, to $75k on the later A1R side. And the extra money is worth every penny when you compare the two.
They aren't nearly as affordable BUT that's not to say they aren't still a "good deal"
My 2008 was $43k in 2021. Adjusted for inflation the original purchase price in 2021 was $276,000. So my purchase was ~15% of retail cost.
Today my truck at $75k would have an adjusted for inflation value of $324,881 and that's now ~23% of the retail cost.
So these are a decent investment having earned 8% more than their adjusted for inflation value over the last 4 years. They aren't making any more after about 2011 and surplus having dried up or been held back for Ukraine hasn't helped the prices any for us consumers.
So they are appreciating currently at the above rate. Will that continue? I think given the current political climate it might.... it looks like at least short term we might see some stagnation in oil prices due in part to lowering of demand from the worldwide EV expansion. Especially like China where consumer fuel demand is falling due to wide adoption of cheap EV's. Tarrifs may cool US imports leading to less shipping and trucking..... I suspect we won't get much below $3 but stagnation at 2019 fuel prices while everything else inflates..... it's not the $1 a gallon from the Clinton administration but if you ignore the taxes that have been lumped in the last 25 years it's not that far off actually.
All of us that get in now though will benefit HUGE in the coming years as the A1P2's enter surplus and the only use for the parts off them will largely be the trucks that all of us already own and the VAST majority of A1P2's will end up being scrapped or sold sans-cab due to the armor. Which means almost all of them are parts trucks.
aw113sgte
1,378
La Crosse, WI
Really hope the armor issue changes, else very little will be available in the future.
rcamacho
914
Any suggestions for LMTV vehicle transport services? Looking to get a few quotes to understand costs before committing to a purchase. Figure at this GVW a lowboy semi is needed
GeneralDisorder
6,030
Portland, OR
You do lose a bit of cred if you don't fly out and drive your purchase home. That's one of the best parts of the purchase and you only get one shot at that rodeo. (Per truck :sneaky:)
It's a bit like this - if you can't get it home (and it isn't off-shore or a basket case pile of poop that ought to be, or IS, a parts vehicle) then what you gonna do when it breaks out in the sticks? For most people the network here and on the Facebook groups IS your support system. That and your own two hands. So getting used to that from the first day of ownership is both educational and ultimately absolutely critical. Those who don't grab this bull by the horns get bucked off. We see it a lot.
GeneralDisorder
6,030
Portland, OR
LOL.
Been there done that. Currently on my 3rd HMMWV and do all the work myself.
First one I drove from CO to WA in early spring. Multiple snowstorms, several days and lots of maintenance later arrived home 🏡 with a good story to tell.
Absolutely. Do that! Transport is so..... Bleh. :cautious:
GeneralDisorder
6,030
Portland, OR
Just did the math for a drive. Figuring 4-6 days with a 12 hour single operator shift. Best case no breakdowns.
Yeah probably. I figured 5 but ended up taking 7. No significant break downs - one stop to change the voltage regulator, had a slight coolant leak that solved itself (truck had never seen cold weather operation - hose clamps needed a couple turns but stopped when they got warm), and then my air compressor started to fail but made it the last 100 miles and then ate itself two days later.
Mostly the added days ended up being museum and attraction visits that were just too good to pass on while driving by them. It was great fun with a good friend and I can't wait to do it again! Maybe next time I'll have more of an "Adventure".....
