- 2,923
- 7,113
- West greenwich/RI
The MOV is not seeing anywhere near 120V, if that's what you're thinking.....?
Hey folks
I've got an 802a generator about 2500 hours
It has never given the rated power output. It is usually happy at about 2,000 watts. Anything above that and it surges.
It just started disconnecting power and the red overload light comes on. Only pulling 1600 watts of power. I have my inverters programmed to only take that much power and I can read how much is being pulled in real time.
Any thoughts what the issues might be?
I wasn't sure what voltage it is seeing. I will order the 14d151k resistor, thank youThe MOV is not seeing anywhere near 120V, if that's what you're thinking.....?
Thank you for your replyYou want to spray the Deoxit in ALL the little opening in the switches by EACH terminal.
Here is a picture pointing out just two of the many openings on the switch's.
The left arrow is pointing to one of the exposed switch contacts in the switch. The switch's are not sealed.
After spraying them you want to exercise the switch's by repeatedly moving them through all their positions many times.
I'd suggest re-spraying and re-exercising them again.
