MEP501 28v to 120v
budthatsmyrealname
Hawaii, Pearl City
I have the mep501a, has the yanmar l48a
i saw a couple old videos on the conversion from 28v to 120v. But those gen heads are nowhere to be found. Id rather direct drive and not belt drive, anyone know of any compatible gen heads? Thanks
kloppk
4,198
Massachusetts
Check with @CallMeColt here on the forum about the conversion and mechacical interface to the L48. He dud a YouTube video about one he converted.
I've converted 831s with the L70 to conventional gen heads. It uses the J609B configuration. The L48 may be the same.
I buy the gen heads direct from Mecc Alte.
budthatsmyrealname
Hawaii, Pearl City
Yes. That was one of the videos i watched. He posted a northern tool with model number but its discontinued. And when you click "search similar items" theyre all belt driven options.
kloppk
4,198
Massachusetts
Northern Tool stopped selling them a number of years ago.
Check out Mecc Alte for the gen head. They are a huge generator head manufacturer. I bought one from them about a year ago for a conversion.
CallMeColt
1,726
Wilson County, Texas
I just saw this & the comment on you YouTube video. That was done quite a long time ago now, no surprise that parts are not longer available. I think the same interface from kloppk's generator head above will work. The J interface is the same if not mistaken across all models IF they have the J interface, and not the keyed shaft.
CallMeColt
1,726
Ok thanks. Great info. Ill go with the s16w 90/2. Is there anything else i need to get or know?
In my opinion, I'd just leave the MEP 501A as it is & find a MEP 531A. In the end, it will be way cheaper. Unless you want the project of course. I wish I had just left it together, but at the time, had no need for the 28v. I'd love to have one again.
budthatsmyrealname
Hawaii, Pearl City
Yes i agree. Already set up is better. I do love projects, but this is what was available at the auction last week and it was my only choice and i need a small gen around 2kw
much appreciated on the responses. Maybe ill post a pic when im done if anyone is interested in seeing the end results 😃
CallMeColt
1,726
I didn't realize until just now your location... that makes things a bit more challenging. I have refurbished ones to sell but it would not be worth the shipping!
2Pbfeet
1,491
Mt. Hamilton, CA
Depending on what you want the power for, you might look for a 24V inverter to get your 120VAC. Prices have come down a lot, though I give you that a bunch of power semiconductors might not have the reliability of a copper coil.
Good luck,
2Pbfeet
  • Like
Reactions: 98G
budthatsmyrealname
Hawaii, Pearl City
Good luck,
2Pbfeet
Yes i thought of just hooking up a pure sine inverter. I could not find one that had 28v input. Unless you know of one i could definitely use that info. I only seen regular inverters and modified sine wave at + or minus a few volts but nothing saying 28. I was gonna use it for electronics. So clean power is important
2Pbfeet
1,491
Mt. Hamilton, CA
Most should accept 28V as it is in the range of charging voltages for a 24V battery bank, e.g. this pure sine 2kW inverter accepts 21-31V
https://www.amazon.com/EDECOA-Power-Inverter-Outlets-Terminal/dp/B08TWDFZBC
I've never used this brand above personally, so I can't comment on it otherwise.
I have used other products from Renogy, and they were of reasonable quality. Here is a 2kw, surge to 4kW rated Renogy (23V-30.7V input);
If you think that you won't be using the full output from thenMEP-501, I might consider a battery bank of some sort between the MEP-501 and the inverter that might give you time to not run the generator. (At the cost of more $$$s and complexity.)
All the best,
2Pbfeet
FarmingSmallKubota
1,392
Wapakoneta, Ohio
Here is a really good discussion on charging batteries from many many years ago.
budthatsmyrealname
Hawaii, Pearl City
So i called mecc alte, he said there was a smaller version, the S16W-75. You think thatll do better than the s16w 90/20? Just wanted to run it by the guys who have done this
this is a learning experience for me. So i appreciate the feedback
