MEP-831A - Huge amount of exhaust smoke
zapp
36
Ohio
Hi -
Hoping you guys can share any insights. I picked this up through GP and just got around to trying to start it. It had been drained of all fluids so I PM'd it and went to try and start. It fired up, however, there was massive smoke flowing out of the exhaust. I also noticed the governor was resting on the magnet while it was running which I thought should have killed the motor. I got it shutdown but wondering if this is a crack somewhere in the block letting engine oil into the firing cycle, valves, or something else? Anybody see this before? I took a video to help visualize below.
https://youtube.com/shorts/r1ZeYZRuUFE?feature=share
Thanks,
Steve
2Pbfeet
1,167
Mt. Hamilton, CA
Hmmm... that looks like oil from here. Does it clear up at all? If not, have you checked the entire intake path to make sure there isn't something plugging it up?
If it doesn't clear up, I would wonder about valve guides or rings being an issue, or even a cracked head, but I would check the air intake first. It is very easy to pull the head.
All the best,
2Pbfeet
zapp
36
Ohio
I thought it looked like oil too with the amount of smoke. I let it run and there is so much smoke that I shut it down - doesn't seem to clear up. Would a bad fuel injector pump cause this type of issue (dumping too much fuel)? I wouldn't expect this level of heavy smoke though?
2Pbfeet
1,167
Mt. Hamilton, CA
Unburnt fuel looks very different; usually either clouds of white smoke (uncombusted fuel) or "rolling coal". Personally, with diesel engines, I have found that it is helpful to become proficient in the different colors of smoke and their possible causes as it can really speed up the diagnostics. A quick search of the archive here and/or the internet should get you lots of pictures and videos.
If the smoke didn't clear, I'd follow the TM, but I would have a look see at the entire intake first. Then it is the usual TM steps. I do think that the return fuel line being Teed into the inlet line for the injection pump does increase the chances of air in the high pressure side which causes all sorts of instabilities for these Yanmar engines in the '831. If you have any doubts about the hoses, I would preemptively put new hoses in. I consider it a "pay now / pay later" thing, and personally, I don't want my generators to fail when I need them.
All the best,
2Pbfeet
zapp
36
Ohio
From the bottom dip stick. I wondered since the unit had been drained of oil/fuel when I got it if someone put oil in the top thinking it was for long term storage benefit and maybe that is what is going on?
I was thinking based on 2bfeet recommendations, I'd try the following to see if I get any better understanding of what is going on:
1/ Pull air filter and look for obstructions
2/ Looks for any fuel leaks/perforations which might cause air in lines.
3/ Bleed fuel line and confirm no air.
4/ Look at IP and see if anything is out of whack.
5/ Pull valve cover and check valve measurements.
If nothing jumps out, start a more detail TM walk through.
2Pbfeet
1,167
Mt. Hamilton, CA
In my limited Yanmar experience, it is unusual for an L70 engine to stutter or stumble the way yours is doing, and @FarmingSmallKubota's suggestion of the injection pump not being engaged properly, or with a bent pin/rack would certainly do it. That is an easy check; remove the inspection plate and look.
If you can, try to use a borescope to look all the way to the intake valve. I sometimes think generators get put on the back shelf as "inoperable" due to issues that are so basic that everyone looking at it didn't consider it, and afterwards folks didn't have the time/manpower to go back to square one to find it.
If you do pull the valve cover, I'd check that the valve clearances are in specifications, and that the tappet rods are straight and not bent. I have seen valves in specification, but with a bent tappet rod, and the engine did not run well at all. I'd have a look in the injector port with the borescope as well, just to rule out debris.
I believe that the 831s have the more complex Yanmar sealing on the valves, but I could be wrong. If they do, it is easy to generate a leak if not all of the parts of seals are put in, or not put in correctly. (I have worked on the L-series engines, but not on an 831.)
All the best,
2Pbfeet
zapp
36
Ohio
So I pulled the head off.. What a pain getting the exhaust off.. There has to be an easier way to get to those two bolts on the exhaust bracket on back of engine. Pics below.. Center part on piston looked wet in the center but seemed more like shiny carbon buildup. I did adjust the valves to .015/mm and noticed the exhaust rocker had a lot of lateral movement (even after adjusting) on the shaft where the intake rocker stay'd pretty much over top of the intake valve. I'm thinking this one probably becomes a parts machine.. Any ideas?
2Pbfeet
1,167
Mt. Hamilton, CA
If it were me, I wouldn't rush to make this a parts machine. Yanmar part are easy to come by, though OEM parts can be on the not so cheap side.
Given what you have found, it seems as if you have an oil leak, probably either a valve guide or a ring, or a cracked piston. If it were me, I would check the valve guides and valve seals, repairing / replacing as necessary (valve seals must be new at each assembly, per the service manual), and perhaps a new rocker arm for the exhaust (did you check to see if the . If you are up for it, I would check the rings, if you do not find anything wrong with the valve guides and seals.
All the best,
2Pbfeet
zapp
36
Ohio
Thanks, I've changed valve seals on a car many years ago so I'll give the seals and a new exhaust rocker arm a try. I need to measure the shaft the rocker rides on to see if it is still in tolerance to confirm. Need to read up on the ring replacements and get a little smarter on the steps for that piece..
2Pbfeet
1,167
Mt. Hamilton, CA
Personally, I like the L-series Yanmar engines. They are built like tanks and are about as simple as diesels can be, making a great place to learn for folks who want to.
The simplicity reminds me of a more modern version of the original Lister engines that you could find all over Africa and Asia, sitting in some dust corner of a shack pumping water, running a milker and cream separator, or running a piece of ag machinery, or dragging a rake through a flooded rice paddy. I am always amazed what some of the field mechanics could and did do to keep the engines running.
Lister CS overhaul and revival story.(CS stands for "cold start", a manual valve to boost compression to start, and then drop it to running compression pressures.)
All the best,
2Pbfeet
