Piatheem
- 2
- 3
- California
The van box need to include the subframe rails.
The box frame is made into the box itself. It sets on top of the upper spacer frame that every truck has already.The van box need to include the subframe rails.
Oh, good to know! Thank youThe box frame is made into the box itself. It sets on top of the upper spacer frame that every truck has already.
I suggested a M109A3 body for a deuce that can be found pretty cheap and about the same size as the 1079 box.I think you're looking for unobtainium. You probably got better luck looking for an s280 shelter as Sean Filner (fastidious restomods YouTube channel) has on his., or make your own with a kit from https://rvglobetrekker.com/.
Eastern surplus might have one or might not. Good luck getting a hold of them!I suggested a M109A3 body for a deuce that can be found pretty cheap and about the same size as the 1079 box.
If you start your voicemail saying I want to spend money dave calls back really quickEastern surplus might have one or might not. Good luck getting a hold of them!
No wonder I never get a call back!If you start your voicemail saying I want to spend money dave calls back really quick
Ok, so ...a M109A3 body for a deuce that can be found pretty cheap .
I know where a whole M1079 parts truck is. Are you still looking for a solution?The van box need to include the subframe rails.
I'm interested. Send me details.I know where a whole M1079 parts truck is. Are you still looking for a solution?
