Carburator manual or drawing for M135 ?
Brad
120
Bolivar, Pa
I have taken the carb apart as far as I dare, and cleaned up pretty well. Really didn't see much signs of dirt. But it could have been something in the float valve I didn't see. Anyway, it would maybe help if I had an exploded view of how this thing goes together, and of course, how to adjust it? It has been years since I did this kind of stuff and I forget some. There is one place I am not sure I have it together properly?
I put it back on and it starts and idles, but was raining hard so we didn't take it out yet.
Also, are there gasket or rebuild kits available for these. It is a 2 barrel Holly, photo attached.
Thanks
USMC 00-08
224
Skiatook, OK
Hi Brad. PM me your email address. I have three Powerpoints I can email you that will walk you through a rebuild. It has pictures, TM info , etc. For whatever reason, Powerpoints are not allowed to be uploaded here.
This place carried carburetor rebuild kits under part number K4125. I do not see it listed now, but I would call them if I were you.
20,726
Beam it to me and I will turn it into a PDF and post it and credit you with it...
Brad
120
Bolivar, Pa
Thanks guys, I appreciate this all very much. I checked with "Mikes" earlier and they do have the kit. But it will be great to see some actual directions on how to do things. My e-mail is :
Thanks again
Brad
120
Bolivar, Pa
Thanks to all. I received everything and do appreciate it. Now if I can only get this thing running right. I did take the carb apart and clean it. It was not dirty. It is still running bad, romping, I call it. Next check will be the electric fuel pump, and the wiring to it. Perhaps a short?
Also I will take a check of the oints.
Thanks to all/
