- 1,172
- 1,381
- Basehor, KS
If I read my TM correctly it should be TB 14 with D 13A connected to itIs that terminal 15, or 14?
A third fuse / 3rd phase is not really necessary for the following reasons:The other thing I wanted to ask you gentlemen is should I be running another fuse and bringing all three a/c lines to the new regulator? I’m planning on using this unit in its original configuration for three phase 208vac to power some hydraulic elevator equipment. I’m sure the regulator will work with two incoming a/c signals, but would it be better to connect all 3?
Copy that, and thank you once again. What an amazing resource this site is with the support and experience from members like yourself! I’ll update as soon I get finished up. Hopefully this evening.A third fuse / 3rd phase is not really necessary for the following reasons:
The ADVR 054 is a single phase Regulator
Terminals A and C are used for Voltage monitoring / regulation
Terminals B and C are used for the actual High Voltage Supply to power the ADVR
It is more important that the two phases terminate on Terminal B and C, as they draw the highest current and the jumper will then supply the phase connected to B to A as well via a Jumper.
The two Terminals B are connected on the circuit board directly
Remember, haste makes waste..............Copy that, and thank you once again. What an amazing resource this site is with the support and experience from members like yourself! I’ll update as soon I get finished up. Hopefully this evening.
Guy ( @Guyfang ), thanks, I checked here as well after the question was posted. Most people never bother looking at them, even when they got the doors open.If I read my TM correctly it should be TB 14 with D 13A connected to it
When in doubt, look at the MEP-005A TM. Some of the TM's are very old and copied too often, they are hard to read. BE ADVISED, the 15 & 30 KW TM's are very well known for having mistakes in the Schematics.
