Alt 1 Problem
DmitriM1028
Centerville, MA
Hi, Does anyone have a picture of the inside of the alternators with the Isolated grounds. I rebuilt my alts. And found an extra washer inside. I don't know where it goes. My pass. Side alt. Is Isolated but my driver's side is not and I'm trying to get them to be the same. Thank you so much.
WWRD99
1,853
York Pa
Is it a small fiberglass type washer? It goes under the rectifier. There should be one for each bolt that holds it in. Usually don't get them in the rebuild kits.
DmitriM1028
Centerville, MA
Yes it is, but I have those washers under there already. I just rebuilt the alternators and I swear I put them together identical, but alt 1 is not isolated ground. And also on Alt 2 the light is blinking on the dash, I cleaned corrosion off the printed circuit board and changed bulbs, RE did the alternator, new belts, new relay. And it's still blinking intermittent but bright. Thank you for your help. Much appreciated 👍
WWRD99
1,853
York Pa
Ok take a pic of the washer you didn't put back in and I'll know which one it is.
