- 1,236
- 1,537
- Basehor, KS
Also looks like they used a "wood block" (drilled out to form a 90) at the top of the conduit instead of an elbow. God knows what else lurks in this structure.From a few days ago. The panel is attached to the conduit on the right, and the ground wire nicely coiled around the ground rod...
WHAT IDIOT DID THAT! Everyone knows you need to wrap the wire clockwise around the screw!!
Looks can be deceiving sometimes...Also looks like they used a "wood block" (drilled out to form a 90) at the top of the conduit instead of an elbow. God knows what else lurks in this structure.![]()
osmosis via the flux capacitor .. it's fine !From a few days ago. The panel is attached to the conduit on the right, and the ground wire nicely coiled around the ground rod...
That setup will work, but don’t touch the railing or anything connected to it. The ground rod looks to be touching the railing and the paint is worn thin quite a few spots.
one of my sideline self-employed ventures before retirement was performing annual grounding/bonding/continuity tests at stoneworking mills and their associated quarries IAW the requirements of MSHA .. Like an automotive inspection station, this sometimes led to me having to also do field repairs on their gensets, electric pit pumps, busted conduits or fittings, failing switchgear, hot/loose connections, and company-owned power distribution equip..That setup will work, but don’t touch the railing or anything connected to it. The ground rod looks to be touching the railing and the paint is worn thin quite a few spots.
