- 1,967
- 1,294
- Paris KY
OK, using the time-tested formula of "# of Drive Gear teeth X axle ratio X (20168 divided by tire diameter) divided by 1001 = # of Driven Gear teeth to use", I determined this: 15 (drive gear teeth) X 3.73 (M1009 rear axle ratio) x 616.99 (20168 divided by your tire diameter of 32.6875) divided by 1001 = 34.48. Or put more simply 15 X 3.73 X 616.99 divided by 1001 = 34.48 required teeth on driven gear for accurate speedometer output.
So you will need to use a light green 34-tooth driven gear GM 9774413 or an orange 35-tooth driven gear GM 9780387. You will also need the GM25512340 sleeve with either of these driven gears. All this is readily available on Ebay. PM me and I will send you a link because the SS website police don't like for us to post links to active Ebay auctions (so dumb).
