24 Volt M Series Light Switch on 12 Volt System
Mud Diver
21
Yorba Linda, CA
Ok, I did the search thing and came up empty. I just got an M38A1 that was converted to a 12 volt electrical system. The headlights and front marker lights will not come on, even though they worked when I bought it. Lights are controlled by a simple two position push/pull switch and im thinking that’s the culprit. There is a three-level light switch mounted on the dash in the correct location and I was wondering if that could be used to control the 12 volt lights. Mainly because it’s there and it water proof.
anyone know if you can use a 24 volt component like this on a 12 volt system? I know the original 24 volt wiring would have been under sized to support 12 volts, but would one component be a big deal. System is fused just after the battery.
