Sitting for 5 years. Help me get it running?! Please!
Dirtdiggler
17
Seattle, WA
Been a bit since I parked her, but she ran well then. After new batteries, nothing when I flip the green switch. Important details below.
Batteries were dead, so I converted from four to two. I'm 95% certain I have it right - tested both 12v and 24 volt just beyond the terminal with a multi-meter. HOWEVER, during installation I did make a mistake and sparks flew. I just re-checked all my terminals and wiring and everything seems solid.
So, what relay/fuse did I burn up or is it perhaps something else resulting from it sitting for five years that's gonna take months to track down?
Ronmar
8,326
Port angeles wa
What NDT said. under the power panel cover in the cab y0u will find 3 round power/test points on the left. 24v, 12v and ground. What do you measure between the 12 and 24 points and the ground point in the cab, and what do they measure when you turn on the ign switch?
RULE 1: VOLTAGE IS NOT GOOD UNLESS TESTED GOOD UNDER LOAD! Like a kink in a garden hose, a bad connection will pass full voltage(pressure) throughout a circuit UNTILL you try and flow current thru it then the voltage will drop off drastically
I doubt you fried anything as they put a diode polarity protection device(PPD) inline between batteries and cab. A diode, like a check valve only lets current flow one way… it is located between the spare tire and the air filter can. It is easiest to access by lowering the spare tire.
What I suspect you are experiencing is a bad connection that won’t pass current when the switch is flipped… but we can confirm the wires are right also…
They ran a 24v line direct from battery to starter solenoid To carry the high current the starter demands.
They ran a second 24v line from battery to 24v batt terminal on the PPD
They ran a 12v line from middle of 24v series batteries to the 12v batt terminal on the PPD.
The alternator 12 and 24v lines run to the PPD batt terminals also
The 12 and 24v load terminals on the PPD run direct to those 12 and 24v test points in the cab power panel…
Battery ground runs from the batteries to the front end of the starter motor housing via a device called a “Shunt” located near/below the PPD. A shunt is a device to measure electrical current through a circuit. It is part of the mostly useless STE system(standardized test equipment) they put on the A0 trucks.
from the front of the starter motor where battery ground is connected, there is a ground strap that runs from the starter ground stud to the drivers frame rail.
THIS IS YOUR MAIN CHASSIS GROUND! There is another strap from alternator to passenger frame rail, and a third important one from front end of passenger frame up to the cab inside the engine hump/tunnel(remove grill to access). In general the grounds on these trucks are junk, they were done after paint and generally rely on a star washer penetrating the paint… they should all be disassembled sanded to bare metal for a good electrical contact with the attached strap and once re-assembles with the star washers in the trash where they belong, paint over the whole assembled connection(bare frame metal, clean bare metal ground strap terminal, lock washer and nut)…
and if you have a NATO power plug, it has a ground lead and 24v lead connected direct to the batteries.
Since the PPD and the Shunt are out in the weather, i suspect those connections are corroded and failing. This is perhaps the most common electrical failure on these trucks.
if you don't have 12 and 24 on the cab test points or it goes away when you turn on the main switch, I suspect you will find a bad power of ground connection at the PPD or shunt, or the batteries are failed, which can be confirmed by measuring battery voltage at the batteries with switch off and switch on
Good Luck!
Dirtdiggler
17
Seattle, WA
This is exactly what I needed!! Thank you!
I was just poking around the PDP trying to figure out where to check voltage.
I removed the NATO power plug wiring yesterday when I did the two battery conversion (brand new batteries).
This is not yet a problem, but the cab latch has failed, so until I remove it I can't get under there to check current at the alternator (or change the oil etc etc obviously so that's on the list too. If there isn't voltage at the PDP, then I'll do that and check/replace the PPD while I'm shoved in behind there. Or after I swing the cab open. I hope the manual cab tilt still works....
This thing was a project when it was running. I'm really committed to getting it back there, but I'm coming to terms with how much work it's going to be to get it there. Really appreciate everyone's support on this.
Thank you again.
Ty
Ronmar
8,326
Port angeles wa
in the power panel, The 3 round terminals(1” in dia female threaded hole) on the left should be: top to botton X1, 24v, X2 12V and ground at the bottom…
The PPD itself is probably fine, the cable terminals and the stacked connection are probably corroded not allowing any real current flow to feed the cab…
yea gotta fix the leaking latch or remove and cap the line to the latch(hose ends are female #4JIC fitting) so you will need a male Jic plug to cap the end of the hydraulic line). Then you can manually release the latch(remove end cap and spring or unbolt it) to raise the cab.
the hand pump reservoir must be full and sealed(it has a Allen head filler plug passenger rear corner on the pump) and the Air Operated Pump up by the air cleaner, must have fluid in it as the hand pump does not have enough fluid in it to lift the cab fully, and when sealed, draws additional fluid from the AOP reservoir as it pulls a vacuum as you pump fluid out of it… The hand pump itself is probably fine, hope the Orings in the control valve are OK, that is usually the failure point in this system…
Dirtdiggler
17
Seattle, WA
So, we have power (25.4v) to the PDP, but nothing at the 12v. And after doing some digging I'm really confused now. All 12v power from the battery goes back to the comms box (m1079) and it does not return. There is 12v leaving the alternator but not coming to it.
So, I don't understand how there could be 12v at the PDP without the truck running? And if we have power to the PDP, would the next appropriate thing to be test the ignition relay?
Thanks!!
Ronmar
8,326
Port angeles wa
There is a power connection from the middle of the 24V battery, 12V to the polarity protection device forward of 1079 box, between spare and air filter. 12V passes thru a diode there and flows on to the X2 12V test point in the power panel and from there is distributed by the PDP. I am aware of no standard 12V connection from battery to 1079 box, it only natively receives 24V thru its harness...
Get the spare off and access the polarity box and I suspect you will find the other end of the 12V cable. Or you are dealing with someone's hack-job:O
Dirtdiggler
17
Seattle, WA
Okay. We need the spare off anyway, and the cab latch. So we'll diagnose further. I'll get some pictures of the wiring to confirm. But it ran for 2 years and 10k miles with the current wiring - but did have a low parasitic battery draw that resulted in dead batteries and was the reason for it's relatively permanent parking spot.
Thank you so much for the help!
Dirtdiggler
17
Seattle, WA
There is a power connection from the middle of the 24V battery, 12V to the polarity protection device forward of 1079 box, between spare and air filter. 12V passes thru a diode there and flows on to the X2 12V test point in the power panel and from there is distributed by the PDP...........Or you are dealing with someone's hack-job:O
Well, here's what we have.
Not seeing a place for the 12v positive on the PPD. Thoughts? Besides "clean those grounds 😁"
And here's the wiring from the battery bank, as it has always been but converted to two batteries - sure looks like the 12v running straight back to the box isn't standard.
Ronmar
8,326
Port angeles wa
Holy Schneikies!
The first pic of the polarity protection device shows it has 4 terminals. Should be a diagram on the side of it showing which terminals are 24V batt, 12V Batt, 24V load and 12V load The alternator and battery leads connect to the 24V Batt and 12V Batt terminals(4 wires onto 2 terminals) so the charge output can feed the batteries. The 24V load and 12V load terminals go direct to the 24 and 12V test points on the left side of the power panel in the cab(X1 and X2).
looking at your pic, there appears to be a pair of large gauge cables connected to the top and bottom terminals, so i suspect those are the 24 and 12v Batt terminals(don't recall off the top of my head, I have one in my shop i can take a pic of later this evening). I suspect those are 24 and 12V batt and alt cables. and connected to the middle terminals are the load cables running to the cab(have to look at the diagram)
Did you misplace a 12V cable over in, or on the way to the battery box, because the PPD appears to have the appropriate number of large cables attached...
The 12V cable up into the box may have been some attempt to simply tap 12V batt power up into the camper box.
on the left of your polarity box pic you can see the instrument shunt. One large cable goes to battery ground and the other large terminal goes to the front end of the starter motor. That is your main ground pathway...
hike
—realizing each day
930
Texas Hill Country
If you zoom into the PPD the bottom lug looks like only one wire is connected? The one coming in from the left doesn't look connected to anything?
Ronmar
8,326
Port angeles wa
I think it is connected, i added some red markup, to a zoomed-in pic below. the 2 arrows are pointing at what looks to be the lower straight edge of the terminal lugs, which appear to be inline with the two cables… but even if it was not connected, where is the other end of that cable on the left?
The bottom terminal stud is the 12V Batt terminal, as the unit is usually oriented with the label toward the front of the truck.
Dirtdiggler
17
Seattle, WA
Sure did. I'm trying to sugar coat with "if I hadn't screwed that up I wouldn't have learned all this (from you) or gotten the spare tire off already.
There's not enough power to turn over though. Checking voltage at the terminals it's 25.7. So next up is removing and cleaning all connections as soon as I fill the hydraulic fluid to get the cab up.
I'll be back next time I do something stupid and don't know it....geez
hike
—realizing each day
930
Texas Hill Country
As usual you are right—
Dirtdiggler
17
Seattle, WA
So the fuel issues persist. The flapper on the primer has a moderate to shitty seal. Sanded the contact surface on the assembly where the very old and hard rubber o-ring hits with 1600g sandpaper and that helped a little bit .After 25-30 pumps fuel is finally through the separator filter and headed towards the fuel lifter. If I try to start it, there's no fuel no matter how long it cranks. Checking the primer, fuel is gone.
So what's the best way to go about locating this vacuum leak? Should I just replace all the old and ready to crack rubber fuel lines, below and above the primer? Replace the primer? The rubber return shouldn't matter, correct? And I don't think there's anyway the line from the tank to the primer could have a leak because even with the subpar flapper seal I can pump fuel to it, and if I pump the entire system full of fuel it doesn't leak back down (at least not quickly).
I'm just reluctant to start replacing parts before knowing what the actual problem is. But I'm going to replace the rubber lines regardless and maybe diagnosing it isn't possible without doing that?
Anyway, I'm going to dig into other's threads, but appreciate any thoughts on this.
Ronmar
8,326
Port angeles wa
Well if the primer will lift fuel to the filter it should be able to push it entirely thru the system and you should be able to get fuel out the return line where it attaches back to the fuel tank. No chance of it starting without filling the gallery in the head completely with fuel…
if you can get it full of fuel, I use a rig like pictured. I disconnect and cap the return line at the tank(JIC6 fittings). I then disconnect the supply line at the tank and connect a air pressure regulator to the supply line at the tank and apply 15PSI. Then look for the wet spots… My worst leakage was actually at the bowl on the racor. My bowl had a crack but since all of the lift lines are under vacuum 100% of the time, it didn’t ever have any fuel on it untill I put 15PSI on it then it immediately started to drip.
did the primer bulb stay in with your finger over the input port like I showed in the video? If it did the primer is fine and you are probably leaking somewhere along that lift line.
you could also throw some test lines on it Jic6 hosebarb and a short hose into a bucket. Disconnect the return line and connect a second short test hose into the bucket. Add some fuel and You should be able to pump fuel from the bucket all the way thru the system and back into the bucket… once you do this you should be able to crank and see the same type fuel flow circulating from and back to the bucket… this would confirm the lift pump is working…
Dirtdiggler
17
Seattle, WA
Well, I think we found the problem..... Pick-up line was so rotten it broke in half in my hands.
We were able to isolate it because while it was obviously failing, we could still pump the engine full of fuel. We put clear hose on the return and pumped it until it was even in height with the primer. Then we waited. After all the bubbles came out, it remained at that level. So a vacuum within the system we had. I removed the line into the primer at the tank and there was nothin in it. So we pulled that line and holy crap. Can't believe it was holding ANYTHING.
