Another problem with M135??
Brad
120
Bolivar, Pa
You guys are probably tired of me asking on here? I know I am very tired.
So this truck has ran fine since I discovered that clogged gas line. And everything should be all tuned up because we replaced EVERYTHING except the ceramic dist cap which looks fine.
Spent the last couple days going over the exhaust system trying to quiet it up some. Really only welded shut a couple small holes in the pipe and muffler, and putting in new donuts.
After that was all done, would not start! Even when we had fuel line trouble it would always start. Now no start.
Checked and had plenty of gas to carb, but the spark at #1 plug looked mighty weak. Talked to a couple friends and the concensus was that the condenser may be bad, even though it was a new one. Started to change it and discovered the screw that holds it in was nearly out. So tightened it up hoping that was the trouble. NO, still no start.
So we changed back to the original condenser we replaced when we initially thought it was the trouble?
It started right up, but did not seem to run well. Took a road test and it ran, but very little power, bad.
So we checked our point gap, was good at .022 as the manual says.
I had my son turn the engine over while I watched for spark at the points. None there, but a big strong spark jumping from the negative pole on the coil up to the main contact of the coil that is where the dist cap goes in when the cap is on, that is distributed to the plugs?
Is this something wrong, or will this stop when the cap is in place, and then spark will be sent the points?
I am sorry to bother you all with my troubles, but we have no where else to turn to??
Thanks in advance for any help.
Barrman
2,170
Giddings, Texas
Trouble with our trucks and finding answers is why we all come to this site.
The spark at the points is what causes the coil to “collapse” and send hi voltage to the distributor cap and plugs. Check your leads around the points and what could be touching the points. Something is causing the coil to collapse and send spark via an alternating route to the spark plugs with proper timing.
rustystud
3,374
Woodinville, Washington
When you were working on the exhaust system did you remove the exhaust manifold ?
For some reason the "governor" keeps popping up in my brain. Have you checked those lines ? The ones from the front of the engine to the carburetor.
OK, now that I got my "wild speculation" out of the way let's get to work.
What does a "Gas" engine need to work.
1) Fuel
2) Ignition (spark)
3) Air
4) Compression
We know we have fuel. You already verified that.
We have spark, but you say it looks weak. We'll get back to that.
Do we know we have "Air" ? Is the "carburetor" working properly, and is the air flow unobstructed ?
We know we have compression, correct ?
So we need to check the carburetor inlet piping and air filter.
Then we need to check the Ignition system again.
Since your truck worked properly after you found the fuel obstruction, we can probably "assume" this problem has come about due to your working on the exhaust system.
Did you use a welder on the pipe ? and if so did you disconnect the battery ?
If you didn't disconnect the battery, you could have fried some of the electrical components.
You should start there.
Brad
120
Bolivar, Pa
Thanks for the quick responses
To Barman: I been trying to understand how all that works inside that enclosed distributor. After a night of think about it, I think that big spark jumping from the neg pole on the coil to the main oriface at the coil top, is probably actually jumping in the other direction? Each time the points close. I think once the cap is back on the hot spark would then go to the plugs?
To Mr Stud"
I have a full flow of gas to the carb now
I removed the air cleaner duct, the carb horn is wide open. I tried starting fluid, nothing.
Compression is very strong. Very hard turning engine by hand to set points.
Exhaust, I immediatly thought we might have an obstruction and that's why there was no power? But all we did add donuts at the joints and tighten everything up. But we took the stack loose at the muffler and passed am old hose down until it came out the other end.
I had the pipes off from the manifold to the muffler, they are wide open.
I did not remove the manifold. The welding done on the pipe and a small patch on the outside of the muffler was all done off the truck. The patch was over a small deteriorated area and did not enter into the muffler.
The points are not burned.
I am busy with other things today but I think tomorrow afternoon all I can do is put in the last new condenser we have, and see what happens?
If it were a gas problem, wouldn't it start on the starting fluid sprayed into to back of the carb? That is why I think it's a spark problem.
Again, thanks so much to all.
This is a quest I have to get going for my Dad and my Son.
Brad
120
Bolivar, Pa
OK, here is the latest,
My Son installed a new condenser this morning and it started right up. Regarding this issue, the previous NEW resistor lasted about ONE WEEK. Maybe we just got a bad one/ Or might there be something causing these to go bad?
Next, as before, NO POWER. On level will only run about 45MGH with pedal to the floor>? Before we never had it floored, it is a fast runner, always had lots of power.
The only thing we did since discovering and clearing the gas clog is to have worked over that exhaust.
After which, it would not even start. Then we replaced the new condenser with an old one and it started right up, but no power. Then the same day that resistor went bad. Now we replace that and again no power?
We did remove the stack pipe from the discharge side of the muffler and it made no difference. I guess we will now try the intake side of the muffler in case some how while working with it something somehow came lose inside and could be restricting exhaust??
Everything regarding the lines for the governor seems intact, otherwise I don't know how to check anything else out? The inside of the distributor looks fine as far as I can see, no rust, etc?
Brad
120
Bolivar, Pa
Have plenty of fuel to the carb. Pump filled a pint glass jar in 20 or 30 seconds. I was looking for water in the gas. Clean as a whistle.
However, I have been told that if the filter appears full, then it is clogged? Have you heard that?
It is in a vertical position and appears about full. I thought that was because all the air could then rise and go thru the system?
Brad
120
Bolivar, Pa
so my son was talking with Mephis Eq ordering a couple new condensers. He was discussing this power proble, They told him to set the points at .016 to .018? The manual says .022.
I have had a few guys tell me .022 is too wide, but thats what the manual says??
Brad
120
Bolivar, Pa
OK, we tried the .018 point gap. Hard start and would not pull out of his barn.
I checked the fuel line where it was clogged before, wide open and again, full flow to the carb.
Disconnected exhaust pipe ahead of the muffler. No difference.
Just no power. Won't run past 40-45?? And some backfiring at times???
Is the governor what controls the spark advance??? The lines all look fine but how could I tell if anything else is wrong with that system????
M37keppy
75
Eldridge, Iowa
You can unhook the steel governor lines at the carb to take the governor out of operation for testing. The governor overrides manual throttle input.
Brad
120
Bolivar, Pa
Will disconnecting the two lines effect the spark advance?
And, when I dissconnect the two lines do I need to cap them at the carb?
I am not understanding this system at all?
We have a standard transmission in this truck, not the original one. Do I even need a governor??
M37keppy
75
Eldridge, Iowa
It will not effect spark advance operation. When testing leave the fittings open so there’s nothing to act on the governor diaphragm. You can not use the governor but there will be nothing to stop the engine from over reving since you no longer have have the hydramatic with it’s own internal governor.
Brad
120
Bolivar, Pa
Thanks for your help with this. I am going to go try this now. Since I am disconnecting those lines at the carb, won't it suck air into the system and effect it's operation. That is what I was meaning may need capped?
This truck has ran fine just the way it is for years. I do not understand how this could now all of a sudden start causing this?
Do you think this trucks gov could have originally been set at around 40-45 mph and is now doing so?
Thanks again, off I go to try this.
M37keppy
75
Eldridge, Iowa
I’m just suggesting it as a test to find out if the governor is an issue. I have found if the governor system isn’t working right it really messes up engine and transmission performance in these trucks.
Brad
120
Bolivar, Pa
Thanks to all that have tried to help. Believe me, we were very frustrated with this trouble and our inability to find the cause. However I think we have it fixed.
We tried the gov test as we were told. No diff.
I even took the valve cover off and looked for a bad rocker, or something obvious. Everything looked great.
Was going to check compression but had to wait for a gauge.
So, I looked in the manual under trouble shooting. As it suggested, we took all the plug wires off at the plugs and checked each one for spark. All were good.
So I decided to check the plugs, even though they were all just newly purchased no more than two weeks ago.
The #1 cyl plug showed NO spark? So I tried #2 plug, and it had spark. Checked the rest and they all had spark, but again checked #1 and NO SPARK!
Cleaned up an old one and installed. And away she went. Back to power.
Now I gotta say this. In the last month we have replaced a lot of components with new. And of those we had a faulty fuel pump, a bad coil, a condenser that didn't last a week, and the same for this spark plug!! Not a week!
We spent a lot of time and effort and consternation trusting parts that should work, but were bad. It will be a lesson to us for sure> I am passing this on for general knowledge, it is really frustrating!
Thanks to all that offered assistance. I am sure we'll be back.
Brad
120
Bolivar, Pa
IT HAS HAPPENED AGAIN!!??
Took the truck to a veterans event last afternoon, and the trouble started again!
Went to town ok. Started to come home and again NO POWER!
I am going to check plugs this afyernoon, it is acting exactly the same as before I found the bad NEW plug. I hope it is the same problem, and if so, is there something that would be causing this? It ran for so many years with no trouble, now this.
Memphis says these are new plugs, not reconditioned. Maybe they are just junk?
Well first I need to confirm that is the problem.
If it were not for my Son, I'd unload this frustrating pc of crap!
